Letter 20004 Remove Di-Chromate... replace with Phosphate [Arizona]am working on developing a relife process for 4130 Steel Tubes that have previously been Cadmium plated with a Di-Chromate seal and then painted. I would like to lightly plastic media blast the paint off and apply phosphate rather than chromate for paint adhesion purposes (ref QQ-P-416 ). Question is... In what condition should the tubes be in before I send them out to be Phosphate coated? I hope not to have to Strip and Replate the Cad but to simply just replace the Chromate with Phosphate. Any input is greatly appreciated. Chad Parkhill
Sept. ++++ I think you'll find it difficult but not impossible to remove the paint and the chromate without removing the cadmium plating--see letter 9406. However, these days the industry tends to use cadmium for corrosion resistance, but only when a combination of its properties is required (lubricity and freedom from gummy corrosion products, for example). So, as long as you're getting rid of the chromate, it may be a good time to substitute zinc or zinc alloy for the cadmium. Good luck.
Dear Reader: please choose what you want to do--
Save
