How to dull (reduce shine of) galvanized sheets & roofs
Galvanized (dipped in molten zinc) surfaces tend to be quite shiny, at least initially. They will oxidize to a much duller gray tone over time, but that dulling can be artificially accelerated by chemical treatments. Read on ...
Q. Hi All,
I make outdoor garden structures from steel. I previously powder coated them however I now want to hot dip galvanize them for longevity.
I would like to dull the surface to give a more aesthetically pleasing look. The photo attached shows the finish I would like to recreate.
46671-2
I've tried copper sulphate ⇦ on eBay or Amazon [affil link] with salt however the result doesn't seem to match want I want. Ultimately I believe I need to induce a Zinc Oxide layer and wondered whether phosphating would be an option?
The scale of production sometimes runs into the 100s and piece sizes can be up to 0.5m2
David
David Rowe
- London, England
September 25, 2023
Citric Acid
(in bulk)
citric_acid on eBay or Amazon
A. Try 5% citric acid
geoff_crowley
Geoff Crowley, galvanizing consultant
Crithwood Ltd.
Bathgate, Scotland, UK
crithwood logo
Q. We had some very shiny black galvanized metal box vents installed on a new asphalt roof. When the sun hits it, your eyes are drawn to those shiny boxes on the roof and it doesn't blend in well. We want to dull the glossiness of the black enamel so it's more of a matte finish.
I'm wondering if gently scuffing it with a magic eraser sponge could dull the surface enough without completely destroying the finish? I know they say not to use magic erasers on shiny metal finishes because it will dull it. But maybe that's exactly what we need. Is there a good chance this might work as an easy fix?
Amy Olson
- OR
June 4, 2025
A. Hi Amy,
The parts you are describing may well be made of galvanized metal, but what you wish to dull down seems to be a painted surface on them rather than the underlying galvanizing.
Unfortunately the SDS (safety data sheet) for Magic Eraser gives no indication about what is in it so we don't know what chemicals you'd be exposing the surface to. So I'd suggest a simple dry abrasive like very fine sandpaper or a Scotch-brite pad instead.
Q. We have a client with a building sided with galvanized steel. It is too shiny and I'm hoping to "age" it artificially.
I realize this is contrary to your aims as finishers, but do appreciate any help you might offer.
thanks,
John Simms
Jackson, Wyoming
A. Hi John. The booklet "Painting Galvanized Steel Structures", available from AGA will answer your question I think. Single copies can be downloaded for free. Good luck!
Q. Did question about aging shiny Galvanized steel get a solution to his problem. I downloaded the texts suggested and found no answer as to how to age Galvanized. I want a dull finish. Any suggestions?
John Massee
sculpture - Galisteo, New Mexico
Ed. note: Sorry for the confusion, John. Applying a zinc phosphate finish as described in the booklet was the solution we were alluding to.
Solution for tin darkening
Q. I have purchased many tin products and would like to know how to darken them. I know that if you rub the finish with Brasso ⇦ on eBay or Amazon [affil link] you will get a darker look. Is there anything that would make the tin even darker? This would give the new tin the aged look that I prefer.
Carol Pritchett
- Spring Grove, Pennsylvania, USA
Black Patina for Zinc/Pewter/Camé
black_patina_for_zinc
A. Hi Carol.
Just as people sometimes call aluminum foil "tin foil", they sometimes call galvanized steel sheet metal "tin", so I'm not totally sure what you mean by "tin products".
Tin is a food-safe element, so some steel items like cookie cutters and baking pans are tin plated steel, but the great majority of sheet metal is galvanized steel, which is not a food-safe material. If the pieces are galvanized you probably want a black patinating solution for zinc
A. Carol, You could try a black patina solution available in stained glass supply stores ⇦ on eBay or Amazon [affil link] .
Kim Stanley
- Rock Hill, South Carolina
Tip: Readers want to learn from your situation;
so some readers skip abstract questions.
Q. I would like to know how I might dull galvanized metal.
James MILLER
- Florence, Massachusetts
61054ext1
A. Hi, James. Please expound on your situation :-)
If you're a galvanizer, this article from the American Galvanizers Association addresses the issue
and thread 34714 and thread 61054 offer some thoughts on it as well.
If you're a consumer trying to apply a dulling process to some existing galvanized sheet metal, you might consider a "patina for zinc" ⇦ on eBay or Amazon [affil link] .
Thread 7671 offers some other approaches for consumers, and possibly for roofers and kitchen contractors, who want to dull an existing finish -- but a finish for a roof or for a galvanized pipe may not be food-safe for a kitchen. Please get back to us with more about your situation.
Thanks, and good luck.
Q. Hello, my name is Jon, and I own an auto restoration/hot rod shop. I am in the process or decorating my new office and I am going for a kinda of industrial look. I am wanting to cover the lower portions of the wall with galvanized tin panels (steel wainscoating). The kind that was the main stay of barns long ago, I call it the wavy kind. These panels are readily available at my local lumberyard, but are just too shiny for my idea. I want to knock the shine down or off and give it a bit of a weathered look. I thought about making a 50/50 mix of muriatic acid and water and try it on a test piece. But I think there may be a safer way. I have seen them use this as wall covering at places like Joe's Crab Shack, Red Lobster etc. Any info would be greatly appreciated. Thank you.
Jon Collier
metal fabricator/car builder - Litchfield, Illinois, USA
A. You can use 200 gm iron-III-chloride/1 lit water solution(you can even make your own solution-just dissolve some scrap iron in muriatic acid and then dilute it with water).Or you can use 5 gm bismuth nitrate/50 gm nitric acid/80 gm tartaric acid/1 lit water solution.Hope it helps and good luck!
A. Jon,
"Tin" panels that are shiny (they are actually steel, not tin) can be dulled with just about any weak acid. Zinc is quite reactive and will react with almost any acid. vinegar would be a cheap source.
Saltwater would do a little dulling, but maybe not fast enough for you.
geoff_crowley
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
crithwood logo
Q. How do I take the shine off of galvanized sheet metal?... someone has suggested washing with sulfuric acid?... I have an old barn.. and have added on to it ... would like to match as much as possible new and old.
many thanks,
Mike Sandoval
sandoval ranch - Santa Ynez, California
May 29, 2008
A. I would hesitate to use an acid on a new galvanized roof. A little too much time, concentration or bad rinsing will leave you with a bare steel roof....which would rust out incredibly quick. If you want it to match it might be a good idea to get new roofing for the old building. The only purpose of the galvanizing is corrosion resistance. If you must do it, use a weak acid like acetic acid (vinegar in bulk on eBay or Amazon [affil link] ), but I wouldn't. It will get to looking old in time.
Trent Kaufman
Trent Kaufman
electroplater - Galva, Illinois
A. If galvanized=zinc plated try 200 gm iron (III) chloride /1 lit water solution (use rubber rubber gloves ⇦ on eBay or Amazon [affil link] and safety googles!). 2 heaping teaspoons of copper sulphate/1 heaping teaspoon kitchen salt/200 ml water solution can be used too. It must be waxed or clearcoated. Metal must be grease free! Hope it helps and good luck!
A. It is so easy!
2 to 5 grams of copper sulphate to a liter of water. Add a pinch of salt.
whalalalalallaala! turns black! if you want a little copper red on it just add more copper sulphate. It works!
Barry M. Umacob
- Philippines
Q. I have installed galvanized countertops in my laundry room, bar, and boy's bathrooms. However, they are really shiny. Do you know of any chemical that will discolor or blacken them up? I want the ugly, mottled, antique look. (The Betlan Corp. did some for Martha Stewarts potting shed, but of course they will not reveal their technique!) I already tried vinegar and baking soda with no result.
Kari Manthei
Decorator/Artist - Texarkana, Texas USA
July 17, 2008
Q. I am also wanting to age some corrugated tin to use on our ceilings. We have tried the vinegar just because it is safe, but it is leaving a white look on the tin that we do not like.
Does anyone have any suggestions as to what we can use that will give us the rustic look but without the white that the the vinegar has left behind?
Penny Owens
- El Dorado, Arkansas, USA
January 7, 2013
Glare from Galvanized Roof
Q. Our neighbours are building a substantial home and garage/workshop with a galvanised roof. The roof is angled at 45 degrees reflecting the sun back towards the row of homes that sit above it on the ridge line. The glare is really severe and only the garage is on!
glare from galvanized roof
What can be done to solve this? Is there are guaranteed glare reduction/retardant products?
Gabby Kent
neighbour - Moss Vale, NSW, Australia
March 25, 2014
Gabby
How about a tree? SILLY
Willie Alexander
- Colorado Springs, Colorado
Actually, if she can get the neighbor to plant a row of trees, which will partially block the sun from hitting the roof in the first place,and partially block the roof from reflecting back to her, it would even be a two-fer. Doesn't sound silly at all.
Of course, by the time the trees grow big enough, the roof should have dulled on its own though.
Q. I realise that planting is a solution, but that is a mid term solution. It's the next 3 years that are the issue. That's how long it will take the hedging to grow, but by then, the roof will have lost its real nasty sheen.
I am guessing here, based on the response that there is no commercial product. Only option is to paint it, I don't think the builder will spray vinegar on it, we (all neighbours have put a petition to the council) are looking for a commercial guaranteed product.
Gabby KENT [returning]
March 31, 2014
A. This is a problem rarely encountered in Scotland for 2 reasons:
1. Such a roof is very rare here for no good reason. Coming originally from NZ, and having also lived in Oz (WA), I know how good that roof is.
2. We don't get enough sun, so any reflected light might be welcomed.
But to a solution.
We often get asked for something to clean new galv - cleaning dirty marks etc off, or suchlike. Our standard use is dilute citric acid . The downside is that it takes the shine off.
You could spray a fine spray of citric acid on it. It takes the shine off quickly and doesn't harm much in the process.
You might want to hose it down later (if you have plenty of water), but watch where the runoff goes. If they collect roof water, then divert it a while until cleaned off.
geoff_crowley
Geoff Crowley
Crithwood Ltd.
crithwood logo
thumbs up signThank you Geoff. I will test it, and if it works well, I will see if I can do it in a large quantity for this roof space.
Cheers.
Gabby Kent [returning]
- Moss Vale
A. I wonder why they are using highly reflecting galvanized sheets for the roof. It would keep the building cooler. If that is the intention, reducing the reflectivity would not be in their interest. One solution is to install solar collectors -- either thermal or photo voltaic -- on the roof. That would put to good use the solar energy which is troubling the neighbors. Of course, it would involve some additional expense.
H.R. Prabhakara - Consultant
Bangalore Plasmatek - Bangalore Karnataka India
Hi, Prabhakara. They don't pick galvanized metal because it is shiny, but because it is corrosion resistant. You're certainly right that putting solar cells on the roof would reduce the heat gain. But actually a white roof will keep a house cooler than a shiny one because white is a good emitter and shiny surfaces are not; touch the hood and the chrome bumper of a white truck sitting in the sun to prove it to yourself, or see letter 11716, "Want to polish shipping container home to keep it cool"
thumbs up sign Thanks Ted. Eyes can deceive!
