Letter 18625
Diamond coating
Dear sir,
I want to know about your composite diamond coating and wants to
set the technology for my commercial uses. I am giving here with my
requirements so please tell me by what way u can help me?
About us: we are diamond polishing plates manufacturer in
surat(gujarat) INDIA. This plate is a round shaped cast iron plate
which rotates on its axes at the speed about 3200 rpm. and the
polishers polishes the diamond on that plate, right now the problem
is that the plate wears time to time so it should be grinded for
reuse. This grinding process vanishes that plates life, and also it
gives less production per day per worker. this days in this
industries diamond coated plates are introducing by some companies,
so we expect from your side the perfect method of diamond coating,
the instruments for coating etc. We want that plate perfectly made in
that way which polishes more diamonds per day and get lesser wear and
tear on surface of plate.
For your hint: we come to know from the other manufacturers of
diamond coated plates they are going in this way. 1- first grinding
the plate surface for perfect level of plate 2- then balance that
plate (rotation) for overcome jumping of plate 3- then sandblast it
for surface cleaning 4- then clean that blasted part with light
hydrochloric acid 5- then wash it with hot water 6- then they are
coating that plates with nitric acid & sulfuric acid (not sure)
and they are using diamond powder of about size 7-10, 10-20 , 14-20
micron. they are coating this plates two times in different vessels
first for 40 minutes and then for 35 mins. 7- after coating they
sprays some chemical on it that are two types ( we don't know the
type of chemical) so we want from your side the perfect method with
detailed ingredients list and instruments.
Seeking your cooperation,
Pravin Chheta
- Surat, Gujarat, India
Dear Reader, please --
- Post a
question on a different subject.
