Plating Electroless Nickel onto a Silver Substrate
Q. Can anybody tell me if electroless nickel can be plated on silver substrate? Is any pre-treatment necessary to condition silver before immersing the sample in electroless nickel/phosphorous solution?
Thanks a lot for your attention.
Madhhumita Datta
Laboratory of Physical Sciences - College Park, Maryland
A. A normal prep cycle for silver will do. EN will not plate, without help, onto silver. A palladium immersion coat will work. More practical is a nickel strike and rapidly rinse and get into the EN, or put the prepped part into the EN and make the part cathodic for a few seconds with some type of anode in the tank that you remove after the EN kicks off.
Lowenheim's "Modern Electroplating" [on AbeBooks, eBay, or Amazon affil links] has a few sentences on it.
Most other references have nothing.
Not many people would have a need for EN over silver.
A. Acidic hypo EN does not work on Ag, but ammonia on eBay or Amazon [affil link] hypo EN does. Substrate surface should be polished, or degreased and soaked in a Thiourea on eBay or Amazon [affil link] -type lightener. Rinse with DI water and plate immediately.
Alex Kozlov
- New Jersey
Q. We are trying to use electroless nickel on silver epoxy (silver paste), but can't do it, can any expert tell me how to do it?
Chris Chu
- China
November 25, 2018
November 2018
"Electroless Plating"
by Mallory & Hajdu
en_mallory1990
A. Hi cousin Chris. It seems to me that James is implying that silver is not catalytic to electroless nickel (and the Lowenheim book he references agrees with him). Alex is saying that it will work with an ammonia based (alkaline) EN process, and Mallory & Hajdu note that boron-based EN on surface mounted capacitors primed with silver paste is widely done.
If you still want to use an acid hypophosphite EN, an alternative might be 'sparking' the process (applying plating electricity for a few seconds to start the deposition process), but while that might be applicable to a large structure, it's probably of no help if you are doing surface mounted electronic components.
So please give us details including what the parts are that you wish to plate, and what type of EN solution you are trying to use, and what you have learned from your efforts to date. Thanks!
Conductive Polymer as catalyst for electroless plating
Q. Can we use the conductive polymer as a catalyst in an electroless plating?
DINESH Cherekar
- Mumbai, India
November 24, 2018
November 2018
A. Hi Dinesh. I believe there is probably no abstract reason preventing it.
But assuming I am right, then your question will sort of devolve into "Is an unknown conductive substance catalytic for an unspecified metal in an unspecified electroless plating process?" And that is, of course, unanswerable. So please introduce yourself and the actual situation. Thanks.
(My mother wanted me to be a dentist)
