-----:Silver or EN plating on Tellurium Copper
Plating onto tellurium copper is different than plating into other grades of copper.
Per two respondents you should start with an acid plating process, not a cyanide plating process, and hot entry is advisable. Another respondent reports success starting with a nickel or copper pyrophosphate strike.
Per a fourth respondent, a cyanide silver strike might be okay but only with a copper etch first.
Q. My name is Sunil, and I run an electroplating business in the city of Jamnagar, India. I need to perform silver plating on tellurium copper. The problem I am encountering during the trials is that the plating turns black in areas where the current density is low.
Shop - Jamnagar (Gujarat)
March 26, 2026
A. Hi Sunil,
We attached your inquiry to an extensive discussion of silver plating on tellurium copper.
The most promising approach seems to be to start with acid copper plating with hot entry.
Q. I have spent hours reading through many of your questions and responses, which has given me a wealth of information regarding the plating process. This site is what the Internet is all about and I would like to compliment you on its creation and maintenance. We designers can never know enough about all of the different materials and processes that we encounter and it is wonderful to have sites like yours to help further our education. Thanks very much.
We have designed a fitting that is to be produced in C14500 tellurium copper, because of its lead-free composition and good machinability -- scheduled for bright silver plating as the final surface finish. I have the general impression that some of the free-machining alloys can create problems with the plating process and as a preventative measure, I am researching this issue to try to give our plating contractor as much information as possible and to try to anticipate and avoid any potential problems. He is not familiar with this particular alloy and I was wondering if anyone has had any experience with it or recommendations that they would care to impart.
Again, many thanks to finishing.com and to all those who have taken the time to respond to inquiries such as this.
Sincerely,
industrial design - Fort Lauderdale, Florida
Ed. note: Thanks for the kind words, Jim. We provide the space but our wonderful and generous readers provide the value 🙂
by N. Kanani
on Amazon or eBay
A. I HAVE HAD TO DEAL WITH THIS MATERIAL FOR MANY YEARS. THE MOST EFFECTIVE METHOD FOR ME HAS BEEN:
1.) REVERSE ELECTROCLEAN (4-6 OPG NAOH OR PROPRIETARY PRODUCT) 3-5 MINS at 4 VOLTS
2.) RINSE
3.) 25-40% HCl DIP 5-30 SECONDS.
4.) RINSE
5.) ACID COPPER PLATE (LIVE ENTRY) 20-40 ASF TO 100-200 MICROINCHES.
6.) RINSE.
SILVER PLATE AS NECESSARY.
NOTE: THIS PROCESS IS EFFECTIVE FOR FLUX FREE MATERIAL, IF FLUX IS PRESENT, SCRUBBING PRIOR TO A/C PLATE MAY BE REQUIRED. THIS MAY SEEM TO BE A SOMEWHAT CRUDE WAY OF PROCESSING, BUT HAS PROVEN TO BE VERY SUCCESSFUL WITH NO DAMAGE TO THE SUBSTRATE. THE MAIN CONCERN WOULD BE IS THIS COPPER UNDERCOAT ACCEPTABLE TO THE CUSTOMER, AND DO TOLERANCES ALLOW FOR THE ADDED THICKNESS? GOOD LUCK.
REGARDS,
metal finishing shop - Gorham, Maine
Preventing tarnishing of Tellurium Copper
Q. I have the opportunity to machine a component for one of my customers made of Tellurium Copper 145. Tarnishing of this part is a concern. This component is part of a fiber optic surgical assembly. Is there a process to prevent Tarnishing of Tellurium Copper 145?
Jeff E [surname deleted for privacy by Editor]- Hamel, Minnesota, USA
A. Hi Jeff. There isn't a lot of tellurium in there, it's 99.5%+ copper. So I suspect, but don't know for certain, that the conventional tarnish preventative treatments for copper -- like sodium benzotriazole ⇦ on eBay or Amazon [affil link] or chromates -- will work on tellurium copper.
A. Contact any of the plating chemical suppliers and they will be glad to help.
Rick Richardson, MSFDayton, Ohio
Ed. note: Thanks Rick. Indeed a commercial copper anti-tarnish solution will contain benzotriazole or similar compounds, but will also come with instructions, help, and an optimized formulation.
Electroless Nickel + Silver Plating on Tellurium Copper
Q. We have to plate TeCu with electroless nickel 100 micro inches, sliver over that 200 -300 microinches , any suggestions on the pre treatment? We are finding black dots inside the component & white patches on the outer surface, any suggestions? ⇦ Answer?
Chethan- Bangalore, India
Q. We want to call out an electroless nickel plating on a C14500 tellurium copper part. We would like to use electroless nickel because of its uniform coverage of irregular shapes, internal surfaces and edges. Its hardness is also a plus. The environment is not corrosive.
Questions:
1) What is the practical minimum thickness range that can be specified?
2) At that minimum thickness range, does heat treatment provide any increased hardness benefit?
3) What callout can we put on the drawing that will be understood by most shops? What do the various classes and types mean? (It looks like the MIL spec is obsolete. Is ASTM the way to go?)
4) Can electroless nickel be used in the United States where there is incidental food contact?
Thanks very much for any help. We have not previously used electroless nickel.
John Bussan
manufacturer - Chicago, Illinois, USA
A. The MIL spec is obsolete, but still available from AMS as AMS C26074.
However, ASTM B-733 is a much better choice for specifying EN coatings.
1) I am assuming from your description that you will be using the coating either for storage protection (anti-tarnish) or a small amount of wear resistance. If this is correct, you will need 0.2 - 0.3 mil of coating to be effective. If wear is more severe, more thickness will be needed.
2) Yes heat treatment will increase the wear resistance of the coating if the wear is light.
3) Using ASTM B-733 your callout would be:
SC1, Type I, Class 1 or 2, which is 0.2 mil minimum thickness, with no phosphorus content requirement, and without or with heat treatment.
4) EN can be used with food handling equipment. However,
NSF 51 now requires that the EN coating be lead free. You will have to add this requirement to the ASTM callout.
Ron Duncan [deceased]
- LaVergne, Tennessee
It is our sad duty to note Ron's passing on Dec. 15, 2006. A brief obituary opens Episode 13 of our Podcast.
Q. Hello:
We have some parts that are manufactured out of 6061 AL, with integral Tellurium Copper inserts. Imagine a .5x6x6" piece of AL, with a 2x2" center section made of the Te-Cu, with a seamless transition from the AL to the Cu (no gaps). The customer wants to electroless nickel plate the entire part. My concern is the different pre-process requirements for Al vs. the copper. Can this be done? Anyone have any experience with EN plating of a two-metal part like this? Many thanks in advance for any help!
Joe Osborn
Manufacturer - Novato, California
April 17, 2014
A. Hi Joe. Sorry, I have no experience with this, and can't find reference to it in my texts or on-line. But we appended your inquiry to this thread. On some other threads Robert Probert has mentioned that an alkaline zinc plating solution is quite similar to a zincating solution and may possibly be used in place of it.
So maybe a possible approach is aluminum pretreatment then a dip into an alkaline zinc plating tank with the power off for a few seconds, then the power on. Then electroless nickel on the zinc plated surface.
Copper is not catalytic to electroless nickel, so if you don't get a zinc electrodeposit on the copper, you need to 'spark' the component to initiate electrolytic deposition of nickel.
I'm sure you well know that plating or chemically processing an assembly of different substrate materials is invariably a very bad idea -- but if there is no way around it, I think it can possibly be done. Good luck.
Cleaning/pretreatment of tellurium copper
Q. We recently switched from pure copper to tellurium copper in some of our products. Since we drill a number of small cross holes in the part, we use a thermal deburr to remove the burrs. The copper was fairly easy to clean and make shiny. The tellurium has proved to be a challenge to get anywhere near the same finish. Any suggestions.
Robert Wakeman- Watertown, SD, USA
? What have your tried before? Are you concerned about the internal holes or just the OD? Do you need a surface improvement or mirror finish?
AF Kenton
Q. We have adhesion strength problems on Tellurium Copper parts after Silver Plating.
Of course, the parts are Pre silver plated. Brass Parts on the same rack are okay, the Tellurium Copper parts show blistering.
Which would be the correct Pretreatment before silver plating or pre silver plating?
Thanks a lot.
- Mexico City , MEXICO
? Hello,
Is it possible to describe your pre-treatment before silver plating (conditions of degreasing, pickling, polishing base material before plating? etc).
Saludos,
- Mexico City, Mexico
? Your cleaning and etch cycles as well as the strike is critical and you have said nothing. Exactly, what are the conditions of your plating operation?
James Watts- Navarre, Florida
A. Tellurium CANNOT be electroplated onto from any cyanide solution. First strike it in any sloppy dirty copper sulphate ⇦ on eBay or Amazon [affil link] solution or any other ACID solution, then the silver cyanide strike will bond.
A. If a nickel strike is allowed, that works; or plating right into a pyro copper bath first. The nickel seems to work better.
Dan Casey- Everett, Massachusetts, USA
Q. Silver plating on tellurium copper:
After silver plating, plating is get peeling after 20-40 hours.
mss - nashik, Maharastra, India.
July 15, 2015
? Hi Ramsing, ![]() Ted Mooney, P.E. RET Striving to live Aloha finishing.com - Pine Beach, New Jersey Need quick confidential answers? $25 Need project assistance? $100/hr. |
Q. Hi there,
I have recently set up a new silver plating plant, plating copper and brass parts to be used as electrical connectors. The reason for plating these parts is for corrosion protection as these connectors are used in highly corrosive environments such as mines and on railways. My plant has been operational for roughly 3 months and I have as much plating experience.
My plating line is as follows:
1. Alkaline Soak/Electroclean,
2. Rinse,
3. Acid dip.
4. Rinse,
5. Copper Strike (cyanide),
6. Rinse,
7. Silver Strike (cyanide),
8. Silver Plate (cyanide),
9. Rinse,
10. Rinse
I get the parts directly from machining. The silver deposits on the brass components are bright, and adhere very well. However, when plating copper components (C147 -- Sulfur bearing copper) there are several problems.
The end result is the copper plated parts are poor, there are a couple of things wrong:
Firstly some of the surfaces have frosting, mainly the machined surfaces, the non-machined surfaces are bright silver.
Secondly, the plating de-laminates (peels-off) when tested, seemingly only the silver strike and silver plating peels off, not the copper strike.
These problems confuse me ... I would expect the machined surfaces to be bright silver given their clean finish; and the plating peeling off most likely means bad cleaning, but if that was the case you would expect the copper layer to peel off also.
A few observations:
- Brass parts come out perfectly, so the problem is only with copper, we use copper 147 for easy machining. I have heard from another plater that C147 oxidises in contact with cyanide however I have not been able to find another source supporting this.
- The machined areas on the parts get a black frosting look during the silver strike, my guess is that this is part of the reason the frosting occurs in the silver plating bath. (The parts have no such phenomenon after the copper strike)
Things I have tried to rectify the problem
- In the first process tank I have tried: Cathodic cleaning with an anodic flash, anodic cleaning, and no electroclean only soak.
- A longer copper strike
- Higher and lower voltages in the silver strike
- Higher and lower voltages in the silver plating bath.
I would like some direction as to why the copper parts turn out so poorly, and what can be done about it.
I have attached some photos to make understanding my problem easier.
Thank you for taking time to read my question, and for any advice you may have.
Juan Kritzinger- Newcastle, NSW, Australia
January 9, 2023
A. I do not know "C-147", but if it contains Tellurium, then you must strike in an acid solution (even acid copper) first. Cyanide will not plate onto bare Tellurium copper. ![]() Robert H Probert Robert H Probert Technical Services Garner, North Carolina ![]() A. In my experience you cannot treat the brass parts the same as the copper. You do not need a copper strike step for your copper parts. My shop Utilizes a persulphate etch step in the plating of copper substrates. A example procedure is as follows: - Boulder Colorado January 10, 2023 |
