Need Teflon Spray Can for Home Cooking Pans/Pots
Disambiguation --
• If you seek a service to re-apply non-stick coatings to your cookware, please see Thread 29692
• For info on how non-stick coatings are made & applied, please see Thread 14968
• This thread is about repair spray; it seems no longer available, but read & comment here or on Thread 10027
Q. I am an ordinary householder who has a few Teflon coated pans in the kitchen, some of which need resurfacing. I was told by a friend that there is a product I can buy to bring them back to being usable.
Please help.
Howard Taylor
- United Kingdom
similarly
Q. I am looking for a Teflon Spray can paint that I want to use it on a cooking material (pots and pan with high temperature). Also, I need the instruction as how to apply the sprayed paint onto a metallic pots/pan. Regards,
Jay F. [surname deleted for privacy by Editor]
- Lexington, Massachusetts
Q. Dear Sirs:
I am trying to find out if there is available a spray can of Teflon which I can use to re-surface pans that have been scratched. Thank you.
Ron Adair
- Colorado Springs, Colorado
Q. I, too, need this Teflon spray in a can for repair purposes in my hobby. Anybody come up with a source? (-:
Tom Hamilton
- Claremore, Oklahoma
A. There are in the market sprays that contains PTFE. Those sprays are used as a releaser in rubber molding. For the applications you mention it does not work well, the coatings onto the cookware must be cured at 400 °C (750 °F) and I suppose you don't have a oven for this temperature. You'd better buy a new frying pan.
Jordi Pujol
- Barcelona, SPAIN
A. The Teflon that is applied to cooking surfaces should be FDA approved. To properly apply this type of Teflon, the area must first be preheated (to release any residual oils) then sandblasted clean. Next the Teflon is sprayed onto the surface and baked in an oven that is approximately 800 °F. I think that the spray you have been writing about was a type of coating that was neither approved for cooking surfaces or for continuous use.
Jan Duncan
- Portland, Oregon
Q. My kids have damaged some very expensive teflon coated pots I own, is there a teflon spray I can use to refinish these pots.
Margaret Dottin
- Ft. Lauderdale, Florida
Q. I was just wondering if there was a positive response to this question, since I have the same type of problem.
Thomas E. Schneider
- Davenport, Iowa
A. Hi, Margaret; Hi, Thomas.
I'm afraid that the answer is no, you cannot repair them that way, but you can find second opinions and good feedback in this thread, and the history of the formerly-available non-stick spray in Thread 10027. Good luck.
Q. There used to be readily available in hardware stores and the like an aerosol can of Teflon spray that could be used to resurface a waffle iron or other cooking utensil that originally came with a Teflon coating. I can't find those anymore, Where can I get one?
J. F. Brauer
- Broomfield, Colorado
A. People have been known to say that the teflon spray had problems sticking to the original teflon and would eventually come off. It may have been recalled, for health reasons.
Many people have issues with cooking on teflon pans to begin with.
H. Mann
- Dudley, Massachusetts
A. Application of real Teflon® / PTFE coatings is a multi-step industrial process, J.F., involving mechanical polishing of the surfaces, special etching, primers, high temperature fusion with proper exhaust and fume scavenging, etc. A bonded Teflon® coating is not something that you can just spray out of a can like paint.
The non-stick repair product you are referring to is discussed in detail in letter 10027, "NON-STICK COOKWARE SPRAY TO FIX POTS & PANS?", but it is not available anymore; and it was not actually teflon -- it was a proprietary mix of Butyl Cellosolve, P.M. Acetate, and Cellosolve Acetate solvents that were cured/baked to hardness.
A. Found this letter in the Minneapolis Star Tribune in the FixitUp Answer and Question section regarding re-coating teflon pans.
"For non-electric cookware, there is one industrial applicator (licensed by Dupont) that does re-coating. [They] will remove the existing coating and apply Silverstone to cookware up to 24 inches in diameter at $10 per pan, plus shipping, sales tax, etc . . . There are no do-it-yourself Teflon spray coating products."
Guess we are out of luck.
Joel Gilb
- Hoffman Estates, Illinois, USA
thumbs up signThanks Joel. I looked up the article that you suggested: the company name was OPI, 2208 S. 19th St., Sheboygan, WI.
As some postings drifted away from consumer-applied sprays to service which offer re-coating, we started new threads to cover those related topics. Please see thread 29692, "Teflon re-coating service for pots & pans".
! Teflon Spray for re-surfacing cooking pans was available several years ago at Hardware Stores. It was taken off the retail market when anti-gun nuts made an issue of Teflon Coated bullets which were outlawed as it was claimed they could penetrate Police Body Armour. If it is once again available then do let us know as I am about to replace some good pans. Thanks.
Ed Rapisardi
- Leesburg, Florida
No! No! No!
Not for Food Service!
Teflon/ Moly Oven Cure Firearm Finish
brownells_gun_finish
thumbs up signHi Ed. We appreciate your effort to help, but I think that story is urban legend. The non-stick repair spray in question was never teflon in the first place, so it wasn't removed from shelves for that reason; and you can't apply teflon to pots and pans that way anyway, so there would not have been spray teflon for pots and pans; and sprayed teflon lubricants and sprayed teflon coatings for other purposes have remained available throughout this whole period .
My personal belief is that times changed, our society became much more risk-averse, chemically safety-conscious (maybe paranoid?) and litigation-oriented ... and it just became too risky to continue to market these kinds of oven-bake-able solvents for use on food-service products.
Q. I have some strap pans used in a bakery for breads. Is there a Teflon spray that can be applied after the current coating effectiveness has diminished.
Dennis T [surname deleted for privacy by Editor]
- Louisville, Kentucky, USA
A. I found this link at eKitchenGadgets.com that advertises a repair coating. I have never used it and am debating with myself over trying it. Or go to www.hometrendscatalog.com and look for product #109041.
I have not yet tried it and can't attest to its efficacy.
James H. King
pest control - Tallahassee, Florida
A. If anyone is interested, I found a Non-Stick Surface Repair Spray in the Harriet Carter gifts catalog. It is 5.98 a can. I have not tried it yet, so I don't know if it's any good.
Charlotte Nickel
- Las Vegas, Nevada
Ed. note: Sorry, we struck through those links because eKitchenGadgets, hometrendscatalog, and Harriet Carter no longer carry that product. We previously removed links to Walter Drake and many others who no longer carry it either. Sorry, but we are quite confident that the product is no longer marketed in America.
A. Our experience is that if the coating (i.e., Teflon spray) goes on easily, it also comes off easily. Yes it is not a simple paint on application, and will become part of your diet. Have a professional shop redo your Teflon.
Lawrence Henry
industrial coating - Edmonton, Alberta, Canada
A. I was at one time looking to re-do my Teflon pans and did find something like you're looking for. All you do is spray it on outdoors and put in oven at a certain temperature (not sure of temperature) and it worked. So now I am also looking for the same product. Don't be afraid to do.
Martha Blocker
- Napa California
August 18, 2012
thumbs up signHi, Martha. Thanks for the tip, but you will find that that spray is no longer available. You can see thread 10027 to follow the history as it went off the market.
August 19, 2012
Q. Is there a Teflon or other composite spray which can be applied to a metal surface and experience operating pressure of about 200 psi and temperature around 400-500 °F?
Eric Puchala
hobbyist - Chicago, Illinois, USA
A. Hi Eric. You can try the previously mentioned Brownells oven-cured teflon/moly coating. But as Lawrence has told us, easy on probably equals easy off :-)
I think you'll probably need an industrially applied coating on an industrially etched and pretreated surface, not a quick and easy spray. And remember that these sprays are not intended for food surfaces! Good luck.
Q. I just read the other postings and was wondering what was with the mold releasing spray being used for resurfacing teflon. Is that safe?
Nicole B. [surname deleted for privacy by Editor]
student - Airdrie, Alberta, Canada
September 26, 2008
A. Hi, Nicole. It's probably reasonably safe in my estimation, for that application -- but you can't use it on food surfaces like pots and pans.
October 1, 2008
Teflon Spray
NOT for food!
teflon_not_for_food
! I found teflon spray by DUPONT at Amazon.
Don Bulloch
- Acworth, Georgia
September 13, 2009
A. Hi, Don. I see teflon lubricants, of course .
But please DON'T EVEN THINK about spraying anything like that onto a food surface! It is not meant for that purpose! Lubricants (besides not sticking to the pan) may be highly poisonous. Quote from the vendor's data sheet: "DO NOT use this product in an attempt to repair or resurface any type of cooking equipment."
September 14, 2009
Q. I need a non sticking spray coating for my carbon steel round die for wood pellet production. The wood pellets get stuck in and not all are discharged.
Do you think the Brownell's Teflon will work?
Rahmat Suhaimi
Biomass production - Malaysia
November 3, 2012
A. Hi. A baked on teflon spray may be of some value for your wood pellet dies, but sending them out for hard chrome plating would probably be a lot more effective. Good luck.
Q. I am a house wife, I have teflon pots and pans that need refurbishing and I can't afford to buy new ones. I need something that I can use to refurbish them with. I need help.
Thank you very much.
Sharon Taylor
house wife - caryville, Tennessee, usa
June 22, 2015
A. Hi Sharon. Unfortunately I think you are going to come up empty as we have here for many years.
Q. Several years ago, grandfather coated an old waffle iron with a coating that has lasted for way over 40 years after he gave it to us. Can anyone tell me what may have been used to coat this waffle iron? I think maybe it was Teflon but not sure. It still works great after using many years.
Paul Vermeulen
- Kingman, Arizona
February 20, 2016
A. Hello all this link Should be useful:
http://www.belray.com/news/non-toxic-food-grade-nsf-h1-registered-dry-ptfe-spray
Tareq Karim
- kharkov, Ukraine
September 30, 2017
thumbs down signThanks Tareq, but that stuff is for 'incidental contact', like spraying the bearings of a conveyor belt in a bakery despite some chance of a tiny amount somehow getting inadvertently transferred into the food. It is certainly not meant to be sprayed onto the cooking side of pots and pans.
A. It was taken off the market. We used this product from Harriet Carter years ago. It never stayed on for long and would flake off, sometimes unnoticed in your food. It was determined to cause many digestive cancers and deemed unsafe by the FDA.
Also, teflon coated pans break down in high heats, also posing a cancer risk. I did a paper on this in college; the info can be googled, "cancer risk linked to teflon cookware." Stick with cast iron or for easy cleanup use stainless steel. Anything burnt on stainless steel can easily be removed by boiling soap and water in the dirty pan for 20 or so minutes.
ranen Ferguson
- Jasper texas usa
February 18, 2018
A. Regarding:Food Grade Non Stick Re-Coating:
I am regular user of Non Stick Cooking/Baking Pans,
I foresee that the bake process auto paint (Matte Finish) may work for re-coating, after a complete preparation of surface needs re-coating.
Zain
Abid Zainul Abedin
Logistics and Supply Chain Consultant - Islamabad, ICT, Pakistan
January 16, 2019
thumbs up sign  Thanks Abid. You may be right, but I would remind users in the USA that the FDA and NSF generally tell us what is acceptable and unacceptable to use on pots & pans ... and I'm not personally aware of auto paint being considered acceptable.
January 2019
Q. Hello, I am Darrell Huskey, just a regular guy trying to invent a serving spoon. I need to know if I can apply Teflon to a serving spoon to make it slick or more slick please. This does not involve high heat.
Darrel Huskey
self employed - concord, North Carolina
March 4, 2019
A. Hi Darrel. You can't apply it yourself (it's an industrial process requiring etching, and evolving carcinogenic gasses during the processing), but yes it can be applied to a serving spoon.
:-( I came here looking for the same thing as everyone else it seems - a solution to repair my damaged Teflon pans - from reading the combined threads - I think I will bite the bullet and buy new pans! yikes!
Amy Krahling
Industrial Safety - SPRING HILL, Florida, USA
March 25, 2020
Q. We have a Smoker that has a Stainless Steel drip tray where everything drops down on it and sticks like crazy, even if you spray it with Pam. It is used at a low temp and does not come in direct contact with food. Can you put a teflon spray on that? What do you recommend?
Laura Ciricillo
- Toms River New Jersey
July 4, 2020
Food-safe Lubricants
foodsafe_lube
A. It's a public forum, anyone can respond. But me, I probably would not buy and spray such a product on it; but you could try Belray No-Tox Food Grade Dry PTFE Spray or Interflon Food Lube or something similar, but only if it specifically says it's okay (if it's not expensive it may not be food-safe). Have you tried mineral oil on eBay or Amazon [affil link] , which is much cheaper?
Q. Interesting thread. I'm here because I've got a bbq grilling spatula that is no longer being made, so I can't simply replace it. But, I'm in love with the thing and want to keep using it. The original spatula has a non-stick coating on it that is beginning to wear away on the edge where it rubs the grilling surface.
Any suggestions on something - anything - that would prolong the life on this thing? Maybe just high-heat flat spray paint?
Steve Muchnick
- Ellicott City, Maryland
September 5, 2020
