Letter 17099
I Need a Coating in a Precision Bolted Joint
I have often encountered the need to protect a mild steel, precision bolted joint from corrosion at the faying interface. The trouble comes with structures too large to fit into special tanks and chambers- for instance, large ground based telescopes and tooling for measuring large mirrors and lenses. I am looking for a coating that: A; can be sprayed or brushed on. B; is thin enough to not alter surface flatness and to not cause elasticity between bolted plates. C; bonds well enough to withstand high stress from bolts. D; is dry and particle free after curing.
Noel Moyer
- Danbury, CT, USA
Dear Reader: please choose what you want to do.
I want to post a question or inquiry of my own.
I want to answer or follow-up on this question publicly (in non-commercial fashion).
I am a supporting advertiser and want to reach the inquirer privately.
