Anodizing: Need Complete Procedure
RECOMMENDED ANODIZING & CHROMATING BOOKS
for Shops, Specifiers & Engineers
pinner
"The Surface Treatment & Finishing of Aluminium and Its Alloys" by Wernick, Pinner & Sheasby (1959 - 2001)
anodizing_runge2018
"The Metallurgy of Anodizing Aluminum" by Jude Mary Runge (2018)
surface_aluminum_king
"Surface Treatment and Finishing of Aluminum" by Robert King (1988)
anodic_ox_alum_henley1982
"Anodic Oxidation of Aluminum and Its Alloys" by V. F. Henley (1982)
alum_finish_reynolds
"Aluminum Finishes Process Manual" by Reynolds Aluminum (1973)
avail from eBay or Amazon
Q. Sir we are the manufacturers of aluminium canisters which are used for packing pharmaceutical but the problem is that when we anodize the canister for 40 mins then the colour of the canister turns to dark grey and when we do it for 15 mins then the spot comes we need 6 - 12 microns on the canisters and we want matte finish and bright silver colour could you please assist me which chemicals that we should use and at which percentage and at what temperature.
I would be very grateful to you if you please explain me the complete procedure from the scratch with all the details. Your prompt reply will be appreciated. Anxiously waiting for your reply.
Thanks/Best regards,
Gaurav Verma
- India
A. Hi Gaurav. The matte finish you desire probably comes from an etching step after the cleaning step and before the desmutting step -- not from conditions in the anodizing tank itself. The bright silver may be a dyeing step or you may want electropolishing or bright dipping of the aluminum.
We can probably help with specific questions, but only books can offer you "the complete procedure from scratch with all the details" because that fills hundreds of pages. Anodizing consultants are available as well.
Q. We are into the field of manufacturing all types of furnaces and silicon carbide heating elements. We have a plan to diversify into other business. As we are not having much experience in the field of anodizing, could you please help us in detail?
Nagaraj G
- Bangalore, Karnataka, India
A. Hi cousin Nagaraj. Briefly it's a process to apply a hard, corrosion resistant, sometimes dyed, finish on aluminum. It usually involves alkaline cleaning, etching, desmutting, the anodizing step per se, optional dyeing, and sealing.
The anodizing step itself involves making the aluminum anodic, via a power supply, in a solution of sulfuric acid.
But I don't think that you could, in a public forum, tell others in detail how to manufacture all types of furnaces or silicon carbide heating elements, and in turn I don't think they can tell you in detail about anodizing either :-)
You might start consult one or more of the above books about anodizing.
Best of luck, and feel free to come back with your questions.
I am a student and I want to know what materials, etc. are needed for anodizing aluminium in a science lab.
Guy Davis
- Aylesbury, Bucks, England
A suitable type of aluminium (say 99.5% pure, or another suitable alloy) as your anode, lead sheet as the cathode, 10% sulfuric acid, a rectifier capable of delivering up to 100A/ft2 and a lot of ice to keep the electrolyte cold
Is this to be chromic or sulfuric or phosphoric anodizing? A trip to the library would help. In sulfuric acid anodizing aluminum will work as well as lead for the cathode. Your power source should go to at least 15 volts at full load. The 10% is by volume if you are using lab grade sulfuric. About 1:1 if you are using battery acid on eBay or Amazon [affil link] . Caution, acid to water, not vice versa and it generates a huge amount of heat. The ice is in an outer double boiler, not in the acid. 72± 2 °F for decent product, mild agitation. Seal in boiling DI water.
