Letter 1799
Electroforming of waveguide
structure
I'm investigating the availability of an electroforming process to
do microwave waveguide channels in copper followed by some
harder/stiffer backup material (ex. nickel?). I'm looking for a final
thickness of greater than .040" for the copper + backup metal. The
structure looks like a line of rectangular tubes where the inside
dims of each tube are 3.4" x 1.8" and they are joined on the 1.8"
dim. The length of the tubes would be 1' or less. The issues I see
are whether each tube has to be done individually and the type of
mandrel / material / draft on the mandrel so the mandrel can be
removed after plating.
Jeff Albom
- El Granada, California
There have been a number of articles in the journals about
electroforming waveguides. A computerized literature search should
find them for you. Hint: use Author='Dini' to cull the list if its
too big.
finishing.com
Brick, New Jersey
