-----Copper Plated Roofing Material
I am looking for copper plating to use as roofing in one style of butterfly house. I need a wholesaler or discount house for small businesses.
Lou Houlehillhaven habitats (bird and butterfly houses)
You may be able to find the copper plated sheet you are seeking, Lou, but my first impression would be that if I were doing it I would either do it in a premium fashion with real copper sheet, or I would do it less expensively with aluminum sheet painted to look like copper -- because copper plated steel sheet will be neither 'real', nor cheap, nor corrosion resistant.
I visited Englert Corp. in Perth Amboy, NJ once and saw their coil coated aluminum which they offer in both a bright copper color that looks like new copper, and a green color that looks like aged copper.
