-----Restoring automotive interior plastic
I am looking for a way to restore automotive interior plastic. The material in question is molded out of polypropylene( I think I spelled it right?) It is from a mid 80's G.M. auto.
I am aware that to paint the plastic & achieve decent adhesion MAY be out of the question. If there is a way to prep the plastic for paint, any suggestions would be greatly appreciated.
If not paint, are there ways to recondition plastic to near new?
Thank You
Patrick LanganTry a two-part polyurethane-acrylate that is cross linked with proper crosslinker and properly prepared for that material
Pete Bagley- Reno, Nevada
One thing to keep in mind is that if anyone has ever tried to protect or revive the finish of your plastic part with ArmorAll ⇦ on eBay or Amazon [affil link] or a similar product, you will be faced with a silicone contamination problem. No common paint or dye will stick to contaminated parts. There is no petrosolvent or cleaner that effectively removes silicone; the only way to get it off is to sand it off. Once the part is free of silicone, a commercial urethane (e.g., Sherwin Williams Polane) or an automotive-grade urethane should perform nicely.
Good luck,
Michel Moninger- Sarasota, Florida
Patrick - You will be able to adhere paint to the PE with a prep product called Bondite and it comes in aerosol or liquid. It is available from Innovative Solutions. Regards,
John HeroldInnovative Solutions - Memphis, Tennessee
Ed. note: We couldn't find this product or company via the net in
1998, and still can't find it in 2008. John if you're still out there, check in.
Try VHT penetrating color dye or Folia Tec interior paint
Israel m Ochoa- San Luis Arizona
