-----Anodizing of IVD aluminum
I am currently interested in a combination coating system that uses IVD aluminum on 7075 T6 followed by hard anodize.
This coating system should provide protection of the substrate from the detrimental affects of hard anodize while at the same time provide a top surface with the beneficial attributes of hard anodize. Initial testing indicates the system will work but I still have not achieved a full up hard anodize surface. Has anyone have any suggestions to achieve the goal?
Douglas Duston- Warner Robins, Georgia
IVD is typically very thin. Hard coat is normally rather thick. In generalaties, anodize uses an equal amount of aluminum as the oxide layer formed. So, if you have a tenth of IVD aluminum and hardcoat to 5 tenths, you have used all of the IVD and 4 tenths of the original 7075 material. So have you really gained anything?
James Watts- Navarre, Florida
You may contact the experts on IVD aluminum at Ipsen International, Rockford, IL. They own the license to manufacture IVD coating systems and provide process support.
Mandar Sunthankar- Fort Collins, Colorado
I am also interested in this subject. I recently sulfuric-anodized some aluminum plated samples of 6061 and am in the process of evaluating, but it looks OK. We used the same parameters (V, A, t) as we use for 7050 aluminum alloy, and got a smooth, uniform, adherent oxide, sealed in dichromate with a nice uniform coloration.
My concern is, how does this combination system perform in fatigue relative to anodize alone? Do you have any plans to look at fatigue? Maybe we can share results.
John UllmanIon Vapor Deposition is a term used in the aerospace industry for ion plated aluminum. Many PVD metallizers can do the deposition for you to any thickness you want. For best reslts for anodizing, the deposit should be burnished several times while building up the thickness. This seals pinholes and densifies the thick deposit.
Donald M. MattoxSociety of Vacuum Coaters
Albuquerque, New Mexico
"Handbook of Physical Vapor Deposition (PVD) Processing" (2010) [on AbeBooks or eBay or Amazon affil links]
and "The Foundations of Vacuum Coating Technology" (2018) on AbeBooks or eBay or Amazon affil links]
We are Anodizing some aluminum alloys to MIL-A-8625 / MIL-PRF-8625 [⇦ this spec on DLA] type 1 or 1B, class 2. We were expecting a non electrically conductive surface. We were suprized to find them conductive. Surface resistance / conductivity is not specified in the MIL specifcation, but a literature search show that it is typically non-conductive. Any comments?
scott newland- Melbourne Fl
Something is wrong with your coating. Our process specification at Bendix Aerospace had a test for electrical resistivity using a probe with a design mentioned somewhere in an old Hotline letter, if I am not mistaken. I might be able to find it in my notes if you cannot locate the reference.
We have been working with the Boeing group in St. Louis that developed the IVD process some twenty years ago. We've found that we can greatly increase the density of the aluminum coating by changing the bias from dc to pulsed high voltage (12 kV or so). Samples treated this way looked very good in salt spray tests -- >40% improvement over conventional processing. Deposition rates remained the same. The densification that this process provides could prove important for the anodizing step.
PVD Consultant & Wine Lover
San Diego, California
We have successfully coated Hard Anodize over IVD Aluminum. NO problem with the IVD Al thickness, as we can reach 4 or 5 thousandths if needed. This is more than thick enough to prevent the anodize from reaching the base material. We have also coated steel with IVD Al and then anodized over the IVD Al.
Jerry Wahlinplating shop - Compton, California
Are there any benefits of aluminum IVD coating over cadmium electroplating other than safety/environmental concerns?
Matt Furin- Naval Aviation Depot - Cherry Point, North Carolina
I did fatigue, tensile testing of an IVD/Type 3 anodize over 7075 base. The effects were equivalent to a type 2 anodize. It provides a hard, protective surface to substrate. There is a problem with sharp corners since the IVD doesn't coat well on the corners.
Douglas DustonMercer Engineering Research Center - Warner Robins, Georgia, USA
August 5, 2013
