Letter 16056
Anodizing that fades
[Washington]
I am a quality control manager working with type II anodizing for
the first time. Some of our parts, after being in the field for three
months or so, get a lighter color to them going from their original
black to a brownish orange color. I believe the problem to be
ultra-violet bleaching and I know that it is from a problem in the
anodizing process. Is their a cheap and easy to perform test that
would readily find the defective anodizing?
Kenneth J. Winward
- Kennewick, WA, U.S.A.
First of two simultaneous responses -- ++
The problem is more likely with the sealing than with the actual
anodizing (although it is also possible that a poor quality dye was
used, the sealing issue is more likely). ASTM B 136 describes a dye
stain test to use to check seal quality on a pass/fail basis. The
test requires Nitric Acid (40%) for two minutes and blue dye for 5
minutes, if there is a color change the parts fail (check out the
spec for more detailed instructions, make sure to rinse and dry the
part in between steps).
Second of two simultaneous responses -- ++
Use the dye stain test on your parts.. its a very easy one. All it
takes (in the case of dyed parts) is a 50% (vol) solution of nitric
acid. Place a drop on the surface, and allow it to remain there for 2
min. Rinse thoroughly. If a spot remains after rinsing, the part is
not sealed adequately, which is what I suspect the problem may be. In
the case of clear (natural, for the purists out there) anodizing, one
would follow up the nitric acid with a drop of Blue 2LW dye for a
period of 5 min, followed by a rinse. If the blue spot remains..then,
once again the part has failed. Abrading the spot with pumice is
allowed in both tests. If the spot does not show after a light
pumicing, then it has passed.
Marc Green
anodizer - Boise, ID, USA
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
