Letter 14721
Seeking plating a set of model tabernacle
furniture
I am designing a model set of the furniture found in the Jewish
temple. I am planning to cast these pieces from a zinc alloy using
rubber molds and a spin-casting system. We are looking to produce
them in lots of around 100 at a time. This makes for around 1800
pieces all together that will need to be finished. For most of the
pieces, I need a surface finish that looks like gold. For one of the
pieces, the surface finish will need to look like polished copper and
another, the largest one (the Brazen Altar), needs to have a rougher
bronze appearance. Are there any suggestions on the type of plating
that would work best? I am finding that many platers do not plate
zinc and fewer yet plate brass. I am looking for a plater based out
of either the US or Canada. While I would prefer the durability and
beauty of plating , would powder coating or paint be better options?
Andrew Cross
- Olds, Alberta, Canada
Dear Reader, please --
- Post a
question on a different subject.
