Letter 14079
Thin film coating of a small inside
diameter
I would like to know if it is possible to deposition coat an
inside diameter of (1.6mm) with propylene gas. This substrate is 13mm
long. I have an 800 watt 13.56 Mhz power supply and two mechanical
pumps, one at each end of a glass tube reactor. I can cook them, I
can etch them, but I haven't been able to coat them. I thought with a
pressure delta from one end to the other I could establish plasma
flow and by restricting the flow through the substrate I would be
able to get a coating. I have tried internal and external filaments.
(induction coil). I can form a low power plasma and coat the glass
tube with propylene, but as soon as I introduce the substrate I get
plasma on both sides, but not inside.
Thanks in advance for all replies.
Robert L Gillooly
Atrium Medical Corp. - Hudson, New Hampshire
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
