Letter 14029
Diamond electro plating on gear
Dear sir,
We are working on making diamond dressing gear (ddg) for gear
teeth honing .ddg is a ground gear with electro plated diamond
normally d-126 .The problem we are facing is that after plating there
is an additional growth of plating in tip and sides which is not
acceptable. The extra growth is about 50 microns.
Please help,
Ravjeet Bomrah
- Pune, India
Hi,
If thickness is your only problem then the solution could be
electroless plating with diamonds. Surface Technology is the
proprietary.
Guillermo Marrufo
Monterrey, NL, Mexico
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
