Letter 13081
Copper aluminum problem
I have a copper heatsink that is cooled with distilled water and
Wetter Water which runs through an aluminum radiator. I am worried
that the copper will destroy the aluminum. I was wondering if my
troubles would disappear if I plated the aluminum with copper??? Does
anyone know how to do this ???
Sal Fortuna
- Malabar, Florida
Try pure ethylene glycol instead of water and you will totally
avoid corrosion problems.
John Tuohy
- Ireland
Sal, your problems might disappear for a time by copper plating
the aluminum (there are many companies that can do that I don't know
if around your area but in the US yes). If you have internal passages
you will need electroless copper. The problem is if the copper gets
perforated your problem will become an immediate and sure failure.
Guillermo Marrufo
Monterrey, NL, Mexico
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
