Letter 13015
Use of Galvanized Metal in Meat
Smoker
To Experts; I am in the meat processing business (not for USDA
certification)local business.
I am building a Meat Smoker that is mostly mostly made out of
Aluminum and steel. This will be heated by 240V Elements up to about
300 F at the most.
The question I have is the meat will not touch any surface of the
smoker accept the hangers that are stainless steel. But I was going
to use galvanize sheeting (same as home heating vent work) for the
inside of the door and a small portion of drip pans, ventalation and
such.
I don't believe the galvanized metal would get any amount of heat
over 400'F but after reading on this and other sites on the web I
wonder if I am going to have the possibility of toxic fumes.
I would use aluminum or staineless but they are either hard to
work with or very pricey for the size of sheets I require.
Thank You,
Craig B
- Cincinnati, Ohio
I would not do it, although I do believe that I see zinc plated
hardware in bar-B-Q grills all the time.
It's not a matter of any real danger in my opinion; rather, that
as a business I feel you should not take the shortcuts that an
individual might for his own use, but should use 'professional grade'
materials (stainless steel) throughout.
finishing.com
Brick, New Jersey
