-----ANODIZING TITANIUM
I'm looking for a process to anodize titanium.
Does anyone know a vendor who supplies the chemistry
thanks, Ken
KEN CLAY1998
Ken,
For the anodizing of titanium we use the following bath.
80 vol% phosphoric acid
10 vol% sulfuric acid
10 vol% water at room temperature.
The color of the anodic layer depends on the anodizing voltage.
Anodizing of titanium can also be done in 3 - 5 w% trisodium phosphate ⇦ on eBay or Amazon [affil link] .
J.H. PenningsTNO INSTITUTE OF INDUSTRIAL TECHNOLOGY
Ken
I have had good luck using the trisodium phosphate ⇦ on eBay or Amazon [affil link] solution mentioned in another response, (3% to 5% by weight). My experience is in small parts of titanium and niobium and I get a large range of very vivid colors with this bath. One thing to remember is that the bath temperature should be kept below 80 degrees Fahrenheit otherwise the process breaks down and etches the workpiece. The resulting greyish surface is difficult to remove, and removal may cause an otherwise accurate part to become out of tolerance.
Howard BaileyI¥m looking for some people that have experience (Books, Publications,....) with : Anodizing Titanium Thanks
TaghezoutTU - Graz - Graz, Austria
