Letter 1361
You might try a clear powder coat like the ones produced by Tiger Drylac. I have seen polished brass crowd control railings and other such polished parts/fittings be successfully clear powdercoated without affecting the color. The trick was to cure at the lowest temp. possible and to ramp up the temp. slowly enough that the powder flows and protects the surface from the atmosphere prior to the heat necessary to cure the coating. If the ramp time was too fast, the parts would oxidize and then darken to an undesirable color. Also, if the cure time and temp. was not controlled at the minimum times the same thing would happen. The thickness of the powder needed to be kept below 3-31/2 mils. However, a high volume of satisfactory parts are being produced using this process. Perhaps this would work for you. The powder coat gave a very durable and pleasing appearance.
Ward Barcafer, CEF
aerospace - Wichita, Kansas
Try paste wax-it darkens slightly, but holds up and the colors still shine.
Missy Hamilton
Save
This Page (why?) - Home - ©1995-2009 finishing.com
