Letter 1280
How is black ceramic coating
done?
I am looking for some information about "ceramic coating", any
kind of black ceramic coating and what is the normal coating
procedure and equipment?
Thanks in Advance!
Shunong Fang
There are several ceramic coatings, thin and thick.
Thin coatings like nitrides can be done by physical vapor
deposition.
Carbide coatings can be done by chemical vapor deposition. These
require expensive equipment & temperatures ranging from 250
degree C to 1000 degree C.
Thicker oxidic coatings can be deposited by plasma spray
processes. These are also expensive and are done at temperatures near
the fusion points of the ceramic powders.
There are also chemically formed ceramic coatings which are the
least expensive of all these coatings.These are done at very low
temperatures. It is possible to produce black ceramic coating. Your
actual requirement can determine the exact process and type of
coating.
K. Balasubramanian
technical coatings
Hello! My name is Cathy. I am currently working at the University
of Oklahoma as a research assistant.
The application we are currently looking at is as follows. We
currently use a small (approx.1 cm diameter, .5 cm wide) ring of
metal that is heated to high temperatures. This ring is fitted around
the end of a magnesium fluoride tube with a small nozzle at the end
of it. The ring is heated so that the fluorine that flows through the
tube and nozzle enters a vacuum chamber at a known temperature and,
therefore, a known velocity.
Unfortunately the metal we use is very low in resistance and uses
a lot of current to get it to the temperatures that we need. It was
noticed that a substance called silicon carbide would use much less
current. Unfortunately it is a very brittle material. It was also
noticed, however, that alumina was a fluorine resistant material and
has been bonded to silicon carbide for use in spark plugs and similar
applications. We were thinking that if we could find a design or have
someone make a sleeve of alumina/silicon carbide/alumina that would
fit over our magnesium fluoride tube where on the end near the nozzle
the appropriate amount of silicon carbide was exposed to create the
heating element this would help solve our problems in less heater
breakdowns and also have better resistance to fluorine.
As luck would have it, someone in the chemistry dept. here already
has an element made of these materials that was made in Japan by
Hitachi. Unfortunately it is a solid rectangular shape and contacting
Hitachi has been very difficult as we have no contact names and I
don't speak Japanese. As far as drawings go, we have only a few
back-of-the-envelope sketches.
It was also recently suggested that the magnesium fluoride tube
that we use could be coated with alumina, a sleeve of silicon carbide
fitted over, and then the silicon carbide coated with alumina. Any
information that you could provide would be greatly appreciated.
Thank you very much.
Sincerely,
Cathy Truett, Undergraduate Research Assistant
University of Oklahoma - Norman, Oklahoma
Cathy, may I suggest a simpler method to verify what you are
trying before spending too much money? Get an aluminum oxide or
similar paste (free sample) form Zircar. This paste is used for
furnace wall repairs, we have tried it in binding other things, and
works well. The same company may sell you the SiC ring or sleeve.
They will send you instructions. You could easily bind the ring over
the fluoride tube.
Mandar
Sunthankar
- Fort Collins, CO
I'm making a research on vanadium recovery from industrial Al
sludge (Bayers Sludge) using activated charcoal. If someone knows
something or wonders about I'll be glad to share my opinions.
Ahmet BurÁin AK
- Turkey
I would like to know about metal coating on ceramic substrate
using electroless and electroplating. Please send to me if you have
any information regarding these two processes
C.S.Lim
- Malacca, Malaysia
procedure and equipment? Thank's
Fauzan Jatayu
- Bandung, Indonesia
Chemically formed ceramic coatings can be done on
stainless steels and they can withstand acidic environments.
They are also smooth and black in colour.
The high temperature properties are determined by the the
grade of stainless steel used. It is better to coat on 316
ss to withstand this temperature of 600 degree C. If the
heating is too sudden, the coatings may spall. If it is
gradual, it will be OK.
K.Balasubramanian
- Madras, Tamil Nadu, India
I have a query regarding coatings for ceramic material. I
would like to reduce the shininess, gloss of the final
surface of the ceramic tile, how should I go about it?
Should I do chemically, and using what kind of chemical
would allow me to do so? Otherwise, what about mechanically?
I would only want to reduce the glossiness so that the feel
is "duller".Thank you for your help.
Angie
assembly - Hong Kong
April 9, 2009
my question for K.Balasubranium.
how can we do black ceramic on gold
Ravi
Chandavarkar
- Mumbai, Maharashtra, India
