Letter 11012
Paint adhesion problem
I am a manufacturing Engineer at Spirent Systems in Wichita KS. We
have been experiencing difficulties painting Alodine coated aluminum.
We have been using a Zinc-Chromate primer that does not want to stick
good to the surface. We use the tape test and it always fails.
Is there any other primer that might work better? Would it adhere
better at a higher temperature, like 80 to 90 Degrees F? We are using
Dupont 491-17 Etch-Primer.
Dale O
- Wichita, Kansas
First of two simultaneous responses +
Hello Dale,
The alodine coating should provide a decent surface for paint to
adhere to without using a primer. Alodining is a chromate conversion
coating, supposed to pass 150 hour salt spray. I'd say quit with the
zinc-chromate and try to paint right over the alodined aluminum. I'd
also stay away from etching primers, the "etch" is usually an acid,
which might negate the usefulness of the alodine. If you can't get
good adhesion, try an epoxy primer, providing you are topcoating with
an opaque color (epoxies chalk outdoors if a clear or tinted topcoat
is used).
Good luck,
Second of two simultaneous responses +
I do not think that your primer is the problem. The first two
things I would investigate would be the Alodine film. Perform the
test on the bare Alodine and see if any of the coating is removed. If
so, then the coating may be too thick and powdery causing a failure
at this interface. The second place I would investigate is the part
handling. Are any soils accumulating on the surface? Is the Alodine
coating given ample time to dry? When the Alodine is dried is it at
an elevated temperature? Normally temps in excess of 150 F begin to
degredate the coating. I hope this gives you some direction in your
investigation.
Best of Luck.
- Ira Donovan,
M.S.F.
- Ed. note: Master
Surface Finisher
is NASF's highest certification level.
- Burns
& McDonnell
- Kansas City, Missouri
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
