Letter 10613
Zinc Plate on 12L14 Leaded
Steel
I am a large volume zinc job shop. Periodically we experience
difficulty plating certain CNC parts made from 12L14(leaded steel).
The process is as follows: soak clean-electroclean-2 rinses-pickle
acid 25% HCL-2 rinses-condition (first rinse after plating)-plating
W/alkaline-non cyanide 1.0oz/gal.zn 15oz/gal NaOH, 3 to 6 amp. per
ft2 -2 post plate rinses-sour .75%HNO3-clear,yellow or black
dichromate. This customer manufactures all his parts (over 200) from
12L14, but only a very few (2) won't plate the first time through the
process.We have skipped the cleaners skipped the acid and we still
(may) have problems with these particular parts. We have run them
once, pulled them off line, let them set 2 or 3 days and replate
satisfactory. All other parts, stampings, CNC W/12L14, weldmnts. cold
roll, hot roll, including parts from this particular CNC customer
plate OK. There does not seem to be a logical explanation to the
problem. WHAT AM I MISSING??
Don Penzenik
- Elkhart, Indiana, USA
See other letters at this website for the missing information.
Search at
http://finishing.com/search for
12L14. You need fluoboric acid et al to activate the steel.
I believe your other parts may not have the best adhesion if all
you are using is HCl.
1: Degrease
2: Electroclean Reverse current (rinse)
3: HCL pickle (about 10 seconds) (rinse)
4: 20% Flouboric or sulfamic acid dip (30 sec-1 min.) (rinse)
5: Plate
Scott J. Johnston
- Grand Rapids, MN, USA
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
