(Cycles thru suppliers)
Letter 1029
I need to electroplate some of my sculptures made from fiberglass. I need to know the different conducting paints available in the market. I also need to know the process to be used to electroplate the fiberglass sculptures.
Expecting a reply. Thanks in advance
Sushil Saraf
Hello, Sushil. We have a FAQ on this at www.finishing.com/faqs/organic.html. The three common approaches are silver (or other conductive) paint; two-part silvering process which uses a soluble silver salt plus a reducing solution; and catalyzation with a palladium and/or tin chloride salt. The first step is to decide which approach is most appropriate for your product. One step not to be dismissed is that it may be necessary to lacquer or otherwise seal the fiberglass if the resin system isn't suitable for immersion in electroplating solutions. Regards,
finishing.com - Brick, NJ
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly
I want to post a new question or inquiry of my own on a different subject
This letter is within a monitored forum, very much "alive" here in 2008. If you spot any broken links or obsolete info, please advise!
