Letter 952
Dave Kinghorn |
You are refering to woods nickel, or electroless nickel strike, per Mil-C-26074 [link is to spec at TechStreet]. The phosphate content is very high. It can go over 10% by weight and the nickel-phosphate volume can go over 30%. That's a lot. You'r heat threating is causing the intermetalic to form as well as oxidize the surface. I wager even in a vacuum, post H.T. autocatalytic nickel will be hard to plate to. My first suggeston is do not heat treat the nickel platings at all. Also,control your phosphate to a minimum. The high phosphate content make plating to woods nickel difficult. This takes good plating control, pH, temperature, solution, the works, but it is possible. Good platers know how to do this. I like to start out with a copper strike, 10 microns or less per MIL C-14550; followed with the woods nickel strike, 10 microns or less and then immediately electro-plate with nickel per QQ-N-290 [link is to spec at TechStreet]. I would not dream of heat treating in the middle of this sequence. Now if you are plating for solderability, you'r not done. After a nickel lay-down of 75 to 125 microns, you immediately coat with gold, 50 microns min per MIL-G-45204. Now you'r done. Poin od Knowledge, in soldering you solder to the nickel, not the gold and phosphate nickel is very hard to solder to. Sulfonate and sulfate nickel is the standard to solderability. If the part has to be heat treated, do it before plating, pickel and clean off the oxides prior to plating. The surface has to be "squeeky" clean. NEVER HEAT TREAT IN THE MIDDLE OF A PLATING PROCESS AND SURELY NOT AFTERWORD. Heat treating really damages platings. In fact, one of the bond tests uses a 300 deg F bake to see if the plating peels off. - - - - - - - - Notice, I didn't ask why !
Lee R. Williams
Save
This Page (why?) - Home - ©1995-2009 finishing.com
