![]() Cycles thru suppliers. |
Letter 720
--- Robert, I agree with the "tin benders", but it depends on
its end use whether it has been seriously compromised or
just compromised. James Watts
--- Mr. Wilson:
--- When one purchases galvanized steel it is either "chem treated" or non "chem treated" Chem treatment is a chromate solution applied at the mill to inhibit the formation of "white rust" It is used where the galvanized steel will not be painted afterwards. Examples include guard rails, trash cans, pails. Non Chem treated galvanized is purchased when the parts are going to be painted. Unfortunately the chem treatment does not allow for typical painting processes. ( I understand that Oakite has a paintable passivation being evaluated by the mills for coil coating applications) You can specify to your steel supplier the type of galvanized desired. As far as removing the "white rust" phosphoric acid is
very effective and is not too aggressive. Remember the
protective zinc has been removed to some degree and a
galvanic site has been created. the part should treated and
painted or the damaged area cut out during fabrication. Dan Zinman |
I believe that you should sort out any panels with white rust, and relegate them to the scrap heap. This is a case where preservation issues in storage have been ignored. I would not want them on my roof.
Tom Pullizzi |
We purchase large quantities of roll formed galvanized profiles. Can you recommend the proper method of storing this material over a period of 12 to 18 months without
We weld, fabricate and powder coat the finished products.
Rob Morgan
mfgr - Kane, Pennsylvania
December 13, 2008 Hi, Rob. I think the principal storage issue is that they be dry and be able to "breathe". My limited understanding is that a fresh supply of carbon dioxide from the air is important to make sure the surface maintains a percentage of carbonate to avoid white rust. Storing the panels touching each other, where they can't breathe, seems to be a principal cause of white rusting. Regards,
February 16, 2009 reading your previous answers to questions on "white rust", besides proper storage, are there any other preventive measures to avoid this? Ramon Soriano
April 26, 2009 how can we monitor and diagnose the white rust on galvanized sheets by chemical analysis? abbas zare |
Save
This Page (why?) - Home - ©1995-2009 finishing.com
