No popups, no spam.
Folks helping folks with
respect.  You'll like it.
  HomeFAQsBooksHelpWanted Mar. '16AdvertiseContactForum Letter 649
The finishing.com Hotline: Serious Education ... plus the most fun you can have in metal finishing. Ted Mooney, Webmaster
Best clear coating for aluminum motorcycle engine parts
Some clearcoating solutions (adv.) pointer
Hello,
I am looking for information on the best clear coating for aluminum motorcycle engine parts, to prevent oxidation, dulling, and powering, in a salt air environment. I've been told that something like a HPC coating or Durabright Finish might be the solution, but would like to hear what others think.
Thanks in Advance
Frank Fanto
We do finishing on many aluminum motorcycle pieces. Anodizing works very well & holds up great.
David A. Kraft
- Long Island City, New York
The best process is Clear Chromate Conversion Coating for this purpose . You can ask from your local surface treatment chemical supplier for it.
yehuda blau
Yehuda Blau
YB Plating Engineering and Quality - Haifa Israel
Frank,
A Plasma Deposited Silicon Oxide coating developed by Dow Chemical has several motorcycle aftermarket suppliers already using it. Salt spray corrosion tests indicate several thousand hours with no attack.
Robert J. Dykhouse
- Corona, California
There are a number of different methods to prevent surface degradation. the first is an anodizing process, The second would be a chromate conversion coating, the third is conversion coat followed by a clear powder coating.
The first step is to quantify your requirements. This could include salt spray, humidity requirements. Are there any heat requirement that the part will be exposed to? Will the part be exposed to gravel and other loose impediments from the ground?
You can get together with pretreatment suppliers, paint suppliers and job shops to review the best preparation based upon your requirements and the substrate.
Good Luck
Dan Zinman
What is the best clear coating for polished aluminum , in terms of durability and ease of application ?
Any advice would be much appreciated.
Lars Westvind
- New York
(2007)
It's not clear whether Frank is a parts manufacturer or a motorcycle owner looking for something simple for his own bike. But the banner at upper right of this page will tell you about some good clear coats that you can apply yourself.
Like with anything else, Lars, and like you probably expected, durability and ease of application tend to be opposites. You'll probably never hear a vendor claim that, although their clear coat may not be the most durable you can buy, at least it's difficult to apply and requires highly specialized equipment :-)
But if you are looking for something you can apply yourself, anodizing and plasma deposited coatings aren't going to be doable, and you will need a spray-on clear coat.
Teds signature
finishing.com
Pine Beach, New Jersey
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It is not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & DevicesUsed & Surplus
©1995-2016 finishing.com     -    Privacy    -    Search
How Google uses data when you visit this site.
