![]() (Cycles thru suppliers). |
Letter 638 Nickel versus Tin Plated Wire---- I recently read the finishing page on the web, and I thought you might be able to help me find some information. I am interested in researching the pros and cons of Nickel versus Tin plated wire for use in the aerospace industry. I was curious to know if you could help direct me to possible sources of this type of information. I would appreciate any information that you have. Thank you. Amy A
Amy, why would you consider using nickel plated wire? I cannot think of any great advantage it would have over commercially available tin or silver plated wire (speaking as a pilot and a plater). James Watts
---- Amy, Good luck
Paul D. Stransky, CEF
---- We restrict the use of anything tin plated for satellite use. Why? Because the stress of a tin plating can result in tin "whiskers." There was a GIDEP Alert about 3 years ago on same. You may wish to check with Boeing's GIDEP representative. Tin whiskers can cause electrical shorts and during a ground test triggered a >200 amp plasma short. Dave Love
October 4, 2008 Amy, TerryFoss
Dear Reader, please --
Save
