Letter 551
Regarding the composite electroplating, especially Ni-SiC composite, Malathy Pushpavanam and her colleagues at Central Electrochemical Research Institute, Karikudi, India seem to have done some work. Her article, "Nickel-Boron Nitride Electrocomposites" published in Metal Finishing, p. 97, June 1995, mentions her earlier work on Ni-SiC composites (references 4 and 5 in this paper). Also, the techniques she followed were described in references 3-6. Reference 3 is a paper published in Metal Finishing, vol. 30(4), p. 39, 1974. Unfortunately, I do not have copies of her other articles.
Hope this info is of some use to you.
Currently, we are also looking into this electrocomposite plating and plating of tungsten carbide particles. With respect to the tungsten carbide particles, we had some success with gold deposition. It is still in experimental stage at this time. We will keep you posted of our success.
Thanking you,
Dr. Kamal Murthy
I do have a copy of a pretty good paper called "Electrochemical
codeposition of inert particles in a metallic matrix" published in
the Journal of Applied Electrochemistry, it lists about 56 references
at the end, I can fax a copy if you think it might help, just let me
know your fax no.
There is also a proprietary process called "Nikasil" on the market,
this is an electrolytic nickel silicon carbide process, I think its
supplied by LPW in Germany, its used in Europe on motorcycle cylinder
bores etc. Hope this helps
Richard
PS Like the hot line great idea, its a good way to chill out just browsing after a hard day at the tank side (aren't they all!)
Richard Guise
- Lowestoft, U.K.
Ted,
Are you still interested in this subject. Worked for a number of years with chromium carbide deposited out of a cobalt sulfate and there are a number of things that are helpful in keeping it plating.
Thanks, all, for your willingness to help! At this point the particular project I was thinking of has been moved to the back burner, but I'm sure that I'll be back on the trail of composite plating hints on another project soon. Thanks again.
Ted Mooney finishing.com Brick, New Jersey |
You're asking three questions.
For the 1st question, you have to pretreat your carbide powder for a good wetting by water (in alkaline solution, for example), and, if you want to use the SiC dissolution in nickel (up to 650°C), you have to pretreat your powder in a fluorhydric solution to dissolve the SiO2 gangue.
It is possible to have a viscosity-enhancing by use of acrylic acid partially polymerized and stabilized by Fe. This product is commercially available under the name "COATEX P 90" (I don't know the distributor in the USA).
For the 3rd question Guglielmi is giving the answer in "Kinetics
of the deposition of inert particles from electrolytic baths" (J.
Electrochem. Soc., 119, 8, 1009-1012 ; aug. 1972). This work was
confirmed by J.R. Roos et al. in the 10th Int. Cong. Met. Finish.,
Proc., 203-207 (1980), by C. Buelens et al. ("Electrochemical aspects
of the codeposition of gold and copper with inert particles", J.
Applied Electrochem., 13, 541-548, 1983). You can also read some
papers written by P.K. Sinha et al. (plating, 60, 1, 55-59 ; 1973),
M. Pushpanavan et al. (Met. Finish., 38-43 ; 1977), and so on
All these papers mentioned the relation between the state of polarization of the cathode (or, if you prefer, the current density) and the particle size. In my experience, it is possible to extend the Guglielmi model to the composite electroless deposits (in this case too, it is easy to define the Tafel's beta lines and to have a preview of the quantity of inert particles include in the deposit). I'd patented this technology in 1986 (us pat. 4 844 739) without any explanation.
I hope these informations were some use for you. My apologies for my bad English.
Best regards.
P.S. What a good idea this hot line ! Now I'm sure I can help somebody or somebody can help me in my research. Thanks to finishing.com.
Pierre Josso -
Office National d'Etudes et de Recherches Aerospatiales (ONERA)
Chatillon - France
---- Thanks for the great response, Pierre!
-- I would like to know if anyone is "brush" plating any of these composite chemistries, in particular the "Nikasil" referred to. There seems to be several companies scattered around the US using Nikasil as a means of salvage of motorcycle (and snowmobile) cylinder bores. I am interested in finding a supplier for the chemical solutions, the preplate steps involved, and anyone having any information regarding the possibility of application by the "brush" or selective method Robin McCullough -
-- Letter 1671 deals with Nikasil, and includes links to several other letters which also do.
Save
This Page (why?) - Home - ©1995-2009 finishing.com
