![]() (Cycles thru suppliers) |
Letter 531
Mike - there is still the potential for hydrogen embrittlement.
Some guidelines we have adopted.
- Use Mil-C-13924
(Mil-DTL-13924 [link is to spec at TechStreet]) specification
instead of AMS2485 [link is to spec at TechStreet], there
are better controls in the Military specification and it provides
details on correct processing for different materials.
- Do not use acid cleaning for high strength steels, vapor blast is
effective for cleaning and surface preparation.
- Require a magnetic particle inspection (MPI) after the Black Oxide
process.
- Oiling of the surface is required after Black Oxide, this oil must
be removed to allow effective MPI and then the oil reapplied after
inspection to assure corrosion protection.
- Acid stripping and re-coating cycles will compound a hydrogen
absorption problem since the part is exposed to the acid longer.
- Use hooks and fixtures made of iron or steel, and mask parts of
assemblies that are not ferrous material to prevent corrosion
contamination of the bath.
- The Black Oxide processing time must be closely controlled to
prevent intergranular attack (IGA) and alkaline embrittlement.
Melissa Parks
aircraft engines
Mike, would you be willing to look at a new PVD plating process for hydrogen-embrittlement-free zinc? No post bake is required. Perfect for high strength steels. Ted is correct, black oxide will not provide sacrificial properties.
Mandar
Sunthankar
- Fort Collins, CO
Hi, Mike,
I believe that the zinc black oxide process is still good choice for your applications because of its most convenience and cost-efficiency.
Hydrogen embrittlement is caused by zinc plating and acid pickling not black treatment. Actually, zinc plating has the least risk of hydrogen embrittlement relative to other metal platings because the electrochemical resistance of hydrogen evolution is quite high on zinc. If zinc plating process is properly controlled with right pH range, current density, temperature, time, and additives, hydrogen embrittlement can be minimized. You may notice that zinc plating has almost 100% current efficiency, which means almost no hydrogen evolution on parts during plating.
Baking should be processed immediately after zinc plating at >200 C for at least 4 hours. This is able to eliminate hydrogen in parts completely. Then the baked parts should be activated in either dilute sulfuric acid or nitric acid, depending on black formulations, and thoroughly rinsed in tape water and DI water respectively immediately before blackening treatment.
Ling Hao
- Grand Rapids, Michigan
Mr. Hao, Your comments are correct, except you didn't mention that the 100% efficiency only applies to Acid Zinc.I think this is important, since Cyanide zinc is quite different in respect of hydrogen embrittlement.
Carlos Cielak
plating shop - Mexico City, DF, Mexico
Hi,
I am khemandas chute working as process engineer desire to start the
blackodising process for our tools,jigs ,fixtures.I don't have any
information about blackodising process.I want to know the chemicals
used & process details,so that i can be able to start this
process.
Khemandas Chute
Sr.Engineer - Aurangabad, Maharashtra, India.
May 5, 2008 Please give the detailed process of blackodising & chemicals used for this process. I need this information for my knowledge & study. Many of our components are blacodised but nobody is thoroughly knowledgeable about the process. Ravindra Jawale
May 10, 2008 Hi, Khemandas. Hi, Ravindra. In addition to the specs, you can get an intro via our FAQ on Black Oxide & Cold Blackening; and there is a good chapter in the Metal Finishing Guidebook. Many people use proprietary chemistry rather than having to try to independently develop an optimum formulation, but expired patents may point the way to workable mixes although not the latest technology. Good luck. Regards,
Save
This Page (why?) - Home - ©1995-2009 finishing.com
