No popups, no spam.
Folks helping folks with
respect.  You'll like it.
  HomeFAQsBooksHelpWanted Mar. '16AdvertiseContactForum Letter 445
The finishing.com Hotline: Serious Education ... plus the most fun you can have in metal finishing. Ted Mooney, Webmaster
Brush plating SS with Wood's Nickel & Gold
I'd love to see a table of surface preps (recipes) for substrates before plating. I know some of this info can be found in the Metal Finishing Guidebook, but there's no substitute for tips from experienced platers - it's an art.
I have a question also, I need to plate some 9-in diameter stainless steel plates (~400 parts) with gold (~3 microns). What surface preps, anneals, strikes, plating solutions would you recommend? I'm leaning towards brush plating due to the size of the parts with a nickel strike (Wood's?) followed with gold. I'd appreciate input from the experts. Thanks,
Fred Elsner
- San Diego, California
"THE" brush plating book:
Electrochemical Metallizing
Brush plating should allow you to deposit gold onto the steel plates. The exact preparatory procedure and preplate required depend on the base material. There is a slight difference between the steps used for a 300 series and a 400 series stainless.
Typical steps for a stainless steel include an electroclean, an etch, a desmutting step (400 series), and an activation followed by a nickel preplate and finally the gold deposit.
If you would like to discuss the brush plating option further, contact me.
Derek Vanek
Independence, Ohio
Thanks for getting back to me so quickly with your advice on plating stainless, it will definitely help me get through the learning curve faster.
Fred Elsner
December 7, 2012
Q. Hello people, I have purchased a stainless steel candlestick holder and tried to gold plate the item.
I degreased it using warm water and washing up liquid.
Dried thoroughly with a fresh paper towel.
Nickel activated it with 6.5v
rinsed with de-ionised water.
dried thoroughly again.
initial gold plate all over at 7.5v
once initial plate was done then began to plate with a view to build thickness.
As I started the gold plating part of the process the item went a dark black color and began to blotch all over. then the parts that took some gold basically looked like stainless steel with dried water streaks on it?
Anyone able to explain what I have done wrong?
When I did same process on salt and pepper shakers from same company and line, then I had no issues and brilliant finish.
thank you.
Chetak Pindolia
- UK
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It is not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & DevicesUsed & Surplus
©1995-2016 finishing.com     -    Privacy    -    Search
How Google uses data when you visit this site.
