---- Sorry, I don't know how to do it. Our environmental directory, however, includes a few people you might want to talk to.
. We are currently researching boron treatment. There appears to be some limited evidence that boron reduction (10 to 30% depending on the concentration - >10 mg/L and process) can be achieved in some conventional treatment plants. No reduction data for boric acid. Research is for a landfill with 10 to 15 mg/L boron levels. Treatment objective is less than 5 mg/L. At levels greater than 50% reduction, literature suggests a micro-filtration process. John Stidwill
. I am also looking for wastewater treatment technologies for the removal of boron.. any current literature? any help greatly appreciated. James P
. We have also been on a 4 month long search for cost effective boron removal from wastewater. The raw wastewater contains varying amounts from 100-1100 mg/l of B (as borate we believe). Conventional treatment technologies (metal hydroxide precipitation) has brought the levels down consistently to 100 mg/l from 1100 and to 30 mg/l from 100. Our goal is to reach levels below 4 mg/l consistently. The only technology which appears to work (thus far) is Ion Exchange. This technology is extremely expensive, and we have been researching other options. The most recent attempt (reverse osmosis) has brought our levels down to 13 mg/l. If you or anyone else has some ideas or success, please let me know. Thank You. Mark E. Morgano, P.E.
. If you're interested in high removal rates of Boron, the way to go is EDI (Electro deionization). Another option is to use two step R.O. which will leave you with 25 % remaining in the feed (75 % removal). Good luck and greetings from the Netherlands Jorg Korver
. We are removing boron from wastewater, using an RO system operating with preconditioned effluent, it is on service since January with consistent results below 10 ppm RogÈrio Toledo de
Almeida
++++ You might want to try filtration using zeolite medium. Or use bentonite clay chemicals. Results are very good. Redzuan Razak
+++++ Boron compounds are reduced under high pH. Depending on the
process and objectives, pH precipitation is likely indicated and
advisable. There are some ion exchange compounds that can achieve the
desired level, again subject to objectives. John Stidwill I would like to ask from others regarding the treatment of high boron influent from leachate wastewater. The leachate wastewater originated from the hazardous waste landfill. I've done few test on chemical precipitation with zinc sulphate and ferrous sulphate. Both chemicals give 50-65% removal of boron. The influent boron concentration is around 150-200 ppm. Is there any other experience in removing boron from wastewater using chemical precipitation. ( RO systems are very expensive and not feasible ). Another question that I have is my treated wastewater especially
from the leachate wastewater turns black after storing in the tank
for few days ( without any movement ). I believe that the black color
is due to the FeS that presence in the water. I tried to aerate the
water and add some sodium hypochlorite to accelerate the sulfide
oxidation to sulphate. However, it seems that it takes along time to
oxidize the FeS. ( adding the hypochlorite oxidizes the sulfide and
produced Fe(OH)3 sludge ). My question is is there any way that I can
solve the issue and should I aerate and add some oxidizing agent in
the equalization tanks prior the treatment with ferric
chloride? Muhamed Jaffar
Save
This Page (why?) - Home - ©1995-2009 finishing.com
