Please excuse this stupid question, but isn't cyanide a
base??? I mean KAuCN is basic, is it not??? If so, then why
do you refer to it as an acidic solution? Or am I just
misinterpreting you answer?
Scott Ksobiech
Milwaukee WI
I know it sounds weird -- and it should sound dangerous
if you have been properly warned about the danger of
poisonous hydrogen cyanide gas evolving when acid and
cyanide are mixed. But, yes, there are acid gold cyanide
plating baths (as well as neutral gold cyanide and alkaline
gold cyanide plating baths).
The gold is so tightly bound to the cyanide that the
cyanide does not independently participate in many chemical
reactions. It is a 'radical' (along the lines of SO4) that
tends to stay bonded together in most situations.
Ted Mooney
finishing.com
Brick, New Jersey |
July 17, 2006
I was working in a company manufacturing nickel stampers.
There we used to do nickel electroforming. We used to put
boric acid in nickel baths because the temperature of the
solution near the cathode used to increase as a result of
which H-OH bond gets weak. And if this OH is not neutralised
by boric acid it used to combine with nickel forming burnt
diposites. Probably the same funda you can apply here.
Let me know if you feel I am right.
Anant Chavan
- Mumbai, India
