HOMEFAQsBOOKS JOBS: Help WantedSuggestions you are here: Hotline/Forum => Letter 187
DEFRIC - FTB 116 / HMB-2 Solid Film Lubricants
----Can you give me any information about a process called DEFRIC - FTB 116 Thanks!
Mr Richard Smith|
S |
Searching for information about a process called "DEFRIC". Possibly of Japanese origin. A nitriding process?
Defric coating is a solid film lubricant which can provide resistance to corrosion and facilitate lubrication in extreme conditions. There are 300 kinds of Defric coats. Main Defric coat products either Molybdenum disulfide or Graphite or Fluorine based Lubricants.
Regarding mode of application... well common method is through Spraying on work piece and then drying in the oven at temperature of about 180 ~ 250 degree C.
Aamer IkramAutomotive/Manufacturing - Lahore, Pakistan
(2006)
We are planning to apply Defric coat HMB-2 to bore of our motorcycle gears.
Since this shall be new coating to us, we would like to know process of applying this coating to bore of gear.
Maker of this coating is requested to quote for process and chemical.
^- Sorry! This RFQ is outdated -^
S |
We are a trading company in Indonesia specially dealing with maintenance chemicals including coatings or paints. maintenance chemicals - Jakarta, DKI, Indonesia ^- Sorry! This RFQ is outdated -^ March 10, 2011 I am looking for additional information regarding Defric coatings. The gentleman in the thread previously stated that there are 300 some odd Defric coatings. My question is, where might I search for this information. Is there a particular company that deals in these. Power Generation - Savannah Georgia USA ^- Privately contact this inquirer -^ |
March 11, 2011
Hi, folks. Defric is a trade name / brand name for one line of solid film lubricants and related coatings. Info is available in the U.S. from Trutec Industries, which is apparently a subsidiary of Nihon Parkerizing of Tokyo, Japan, which has other subsidiaries around the world from whom it may also be available. Please google for further info. Our supporting advertisers cheerfully make this site available to us all for technical discussions and camaraderie, but might get a bit snitty about being billed the cost of maintaining detailed distributorship info for their competitors :-)
Ted Mooney, P.E. RET finishing.com Brick, New Jersey |
May 17, 2011
The coating thickness allowance must be calculated and incorporated in the drawing of the component on which the coating has to be applied.
Aamer IkramEnergy Sector - Calgary, AB, Canada
