letter 175
Experiences with black nickel
plating
Lately we have had several requests in our shop for "black
nickel". I understand that this can be accomplished in an EN
bath during a post plate process, using a common EN strip, or even
nitric acid. Anyone have suggestions, experience, with this
process? Is the application functional or simply aesthetic?
Jim
JAMES D MCCARRICK
A black nickel coating is usually accomplished by electro- rather
than electroless deposition. The best known bath forms a Zn-Ni
deposit that is very thin (1-2 micrometers, if memory serves) and
black in color. The protective value of these coatings is minimal,
they are mostly used for decorative and functional (solar energy heat
exchangers) applications over a protective layer of Ni or Ni-Cu.
November 21, 2008
Good point, Berl. Thanks. Letter 7077
also talks about black nickel plating.
finishing.com
Brick, New Jersey
