Letter 156
Minimizing grain size in gold
plating
I need to plate thin gold (400 nm) with the smallest possible
grain size (10 nm or less) onto sputter-deposited gold. I am using a
commercial bath which yields a grain diameter of 40-60 nm. Plating
efficiency and plating rate are not important (slower may give better
control). Any ideas on a specific formula or commercial bath? Does
anyone understand what plating parameters or additives could be used
to reduce grain size? Thanks in advance,
Bill Bishop
Pulse plate it. There are hundreds of articles available on this
exact subject. The AESF is a good place to start your
investigation(links available from this site) along with
Metal Finishing magazine. AESF will
do lit searches for you. Pulsing in the tenths of milliseconds range
may yield the desired result, or you can get special pulse units that
can do hundredths of millisecond pulses. Contact
Dynatronix Inc. [Amery, WI]
for power supplies.
Dave,
Dave Kinghorn
Chemical Engineer
SUNNYvale, California
