Letter 126
Equipment for solution monitoring and maintenance
I am interested in obtaining any information on automated solution monitoring and maintenance for electroplating. I would also be interested in any information about software or methods for calculating the amount of metal the would be plated onto zinc parts of all shapes and sizes. Please reply if you have any such information. Thank you.
Glenn A. Van Noord
An observation is that Walgren (Grand Rapids, Mich.) seems the plating supplier most aggressively marketing automated solution monitoring and maintenance. You might start with them. That doesn't mean I recommend them; I have no personal experience with their system. As for the amount of metal that will be deposited, start with Faraday's Law coupled with the accepted efficiency of the plating process in question. The Metal Finishing Guidebook (Elsevier Science) can get you well started on this.
Finishing.com Inc. - Brick, NJ
Mr. Van Noord asked about systems for automated solution monitoring and maintenance for electroplating. Walgren, which you mentioned in your reply, has changed its name or merged with Parker Systems. The sales rep I've talked to is Mary Lynn [California, area code 408]. Also, Sanda Corporation sells a system - one of their reps is John Boslett [New York, area code 607]. Good luck in finding what you need, Glenn! -
Brenda Daniel
Concurrent Technologies Corporation
Thanks for the update, Ms. Daniel.
Dear Reader: please choose what you want to do.
I want to post a question or inquiry of my own.
I want to answer or follow-up on this question publicly
This letter is within a monitored forum, very much "alive" here in 2008. If you spot any broken links or obsolete info, please advise!
