Letter 125 Implications of phasing out Cadmium and Chromium----- Hi, Environment Canada is considering new regulations that could phase out Cr & Cd plating . I am looking at the status of commercialy useable replacements for Cr & Cd plating. I do have some information for I atttended the fall meeting of the American Society for Metals in Cleveland last month :Surface Engineering Symposium. I also know that the USAF is doing research in this area. I am trying to evaluate the importance the growth of Cr & Cd replacement and the need of our industry in Canada to look to replacement processes. Could you suggest some names of experts who could fill me in on the status of this trend and what is driving it? Thanks Beauchamp, Emile -
What is driving the trend is recognition of the toxicity of cadmium and chromium. Cadmium is a chronic, accumulating poison like mercury and lead; the booklet "Using Cadmium Safely" by the Cadmium Council, Reston, Virginia USA provides a good introduction to the issue. Chromium, at least hexavalent chromium, is a carcinogen; NIOSH Technical Report 85-102, "Control Technology Assessment: Metal Plating & Cleaning Operations" summarizes and references numerous studies of the subject over the last 60 years that seem to prove it pretty conclusively. Twenty years ago cadmium was used rather indiscriminantly-- interchangeably with zinc. And for two decades we've been chipping away at its use, replacing it in the easier applications first. Now it's never used by informed people simply for corrosion protection--only where its combination of properties (compatibility with aluminum, freedom from gummy corrosion products, sacrificial protection, lubricity, and softness) make replacement very difficult. It is one thing to say muffler hardware, which will be torched off by mechanics, ought not be cadmium--but it is altogether different to tell an airplane manufacturer that the one fastener coating found to not cause catastrophic failure of airplane wings is now forbidden, or to tell a fire extinguisher manufacturer that he must use a plating on his trigger mechanisms which is known to cause jamming! Similarly with chrome. Where hardness is required, electroless nickel may do. Where low coefficient of friction is required, teflon may suffice. Where preventing nickel from tarnishing is required, a proprietary cobalt may be fine. But where hardness, wear resistance, freedom from galling, and the ability to hold oil are required, well, "you can't make a silk purse out of a sow's ear". At a recent A.E.S.F. meeting the European lecturer was showing slides about eliminating the use of toxic metals. His brand new slide projector kept snagging and hanging up. He couldn't understand why some of us surface finishers were giggling with the irony of it, suffering through the watching of a slide presentation about eliminating cadmium and chrome on a brand new projector that was an expensive but worthless piece of junk because cadmium and chrome had been designed out of it! It is in society's interest to keep the pressure on toward reducing cadmium and chrome usage. But it gets progressively more difficult and costly, and there is surely a place, beyond the point of diminishing returns, where chemical paranoia will cost lives. I find it disconcerting that we judge chemicals by arbitrary ethereal statistical formulae like "1 in 100,000 increase in cancer mortality" without being mindful that unrelenting pressure on engineers to prescribe obviously inferior substitute finishes will predictably cause catastrophic, death-dealing, failures.
Dear Reader: please choose what you want to do.
Save
