Letter 114
----- Many thanks for the Tafa info. Considering buying the Tafa equipment we have talked with some major clients about the process. Most of them know the process of spraying zinc but don't see it as a replacement for hot dipping of zinc. Altogether one can say that the process over here is little known, and thus opinions are reserved about the quality. We should prefer such a process above hot dipping because we lose jit-delivery control and receive the materials often deformed.[Lorry- transport of about 70 km]. Does such a process withstand weather conditions like hot dipped zinc? Is there an adhesion problem? Can the layer thickness be controlled in an semi-automated process? Are we right to convince our costumers? Is there really a fe-contamination in hot dipping and how severe is the risk? Does sprayed zinc withstand better the outside air? Is the whole process of shot blasting and gunning zinc really less expensive? Sorry for the amount of questions, but I'm a doubting soul whether we should go one way or another. Many thanks, Van de Walle Ghislain
The only questions that I have any familiarity with are: 1). Iron contamination is not supposed to be a real
problem in a well-operated hot dip line. The advertisers in our directory listings may have some answers for your questions.
Save
This Page (why?) - Home - ©1995-2009 finishing.com
