Letter 113
Zinc plating is rusting in blind
holes
I have a plating problem that concerns a 5/16 cold rolled steel
and I have spec'ed a finish of zinc plating on. There are a number of
blind, tapped holes (8-32) end-on into the 5/16 thickness. The
problem is that after the part gets plated, rust appears days later
inside the tapped holes. i have talked to my plater about the
problem, and he assures me he is following this procedure: 1.
ultrasonic cleaning. 2. water rinse. 3. electro cleaning. 4. water
rinse. 5. descaler. 6. water rinse. 7. cyanide pretreatment. 8. water
rinse. 9. zinc plating. 10. water rinse. 11. chromate 12. four water
rinses 13. hot water rinse.
If this is the proper plating procedure, and every thing here
looks like the right set of steps, why else might I be getting the
rust inside the holes after a few days? Any help would be
appreciated.
Ronny Tallman -
This problem is more about managing expectations than technique.
In typical commercial zinc plating, rust inside tapped holes like
this is a common thing because there is no plating inside the holes.
In fact, some platers (with their customer's permission) stopper the
holes during processing to minimize dragover and contamination rather
than pretend there will be plating there.
If the inside of the holes MUST be plated, they can be. But this
involves detailed handwork like putting a piece of wire (auxiliary
anode) into the hole, and inverting the part in every tank so that
neither air pockets nor cupped solution interfere with the process.
But this is not the usual commercial practice. Sorry to be the
messenger.
Finishing.com Inc. - Brick,
NJ
Dear Reader: please choose what you want to do.
- I want to post a
question or inquiry of my
own.
- I want to answer this question publicly
- This letter is within a
monitored
forum, very much "alive" here in 2008. If you spot any broken
links or obsolete info, please advise!
