Letter 044 -----
----- Rob, I used to copper plate circuit boards a long time ago. When I started my employment at this place, they could not plate out of their acid copper consistently. The amperage would fall and the voltage would rise. Come to find out the anodes were not phosphorized, but OFHC (Oxygen Free High Conductivity, I think). If you use the wrong anode material in an acid copper (if you are using an acid copper solution), the anodes will become insulated and you won't draw any amperage. I have checked my training manual on acid copper, but it doesn't say what the anode hook material should be. I thought we used monel hooks, but I could be wrong. Please specify the type of copper plating solution you are using and the concentrations of the copper sulfate, sulfuric acid and chloride level. I can dig up other information or possible solutions. One more thing: Have you bagged the anodes? Let me know. Matt Gazo
+++++ Matt is certainly right that phosphorized anodes are correct for acid copper plating, but I'm not sure that I'd agree that the lack of phosphor is what is causing the particular problem you are experiencing. Lack of chloride sounds more likely if the problem is not simply bad contact, which would be my first bet.
Save
This Page (why?) - Home - ©1995-2009 finishing.com
