![]() Cycles thru suppliers. |
Letter 040
----- I understand that the white bloom that occasionally forms on damp galvanized steel is zinc hydroxide. I have been told the zinc can be protected from this corrosion if a layer of zinc carbonate is formed over the zinc. Do you know any thing about this mechanism - it's chemistry, how the carbonate layer can be formed, and how effective it is? Thanks for comments in advance. Gordon J Esplin
++++ I think the thrust of what you have been reading, Gordon, is that if galvanized steel sheets are stored in a stack outside, or where they can stay moist, and they can't "breathe" because they are stacked, then they are prone to getting zinc hydroxide white rust "wet storage stains" . . . Whereas if they are open to the carbon dioxide in the air--such as when they are actually in use mounted on a building--then there is good tendency for the formation of a more corrosion resistant skin which includes zinc carbonates. If I have misunderstood, or if anyone has a deeper appreciation of the issue to enlighten me with, let me know please.
Save
This Page (why?) - Home - ©1995-2009 finishing.com
