Letter 0024
Activation of Alloy 55 SST
(1995)
Teaching the AESF L.A. Branch this semester, and several students mention problems with plating Alloy 55 (stainless steel) without blisters. They say they use Wood's Nickel Strike after etching, rinsing, etc. But after baking at 375 for 23 hours (per spec), they get blisters, Would using a special copper strike after the Wood's Nickel or in place of it be a possible cure?
Best regards, Myron
Myron E. Browning
L.A. Branch AESF
Many years ago I ran a line plating mil-spec cad, watts ni, and ni-cad. Process was electro-clean in a cyanide based deruster/cleaner with a periodic reverse (5 min racks, 10-15 bbls), rinse, HCl pickle (also on periodic reverse),10-15 sec, (leave on reverse cycle) rinse, woods ni strike, rinse, then to process (cad/ni etc.)   Many of these parts went on to bake afterward, without difficulty (that I'm aware of) leading me to believe that the surface prep cleaning may be responsible for your blistering
Ron Landrette
plating equipment supplier - Bristol, Connecticut
May 17, 2009
Hi, folks. I think the best source of good information on Wood's Nickel Strike and adhesion to stainless steel is found in Dini's "Electrodeposition: The Materials Science of Coatings and Substrates", where he gives tested adhesion values for various operating parameters.
finishing.com
Brick, New Jersey
Electrodeposition, the Materials Science of Coatings and Substrates, Jack W. Dini
Dear Reader
Post an answer
Post a question
Report broken links
List of Directories
