![]() Cycles thru suppliers. |
Letter 0016 Waste Water Treatment
----- Dear Mr. Mooney : Thank you for your reply. I forgot to mention, but we tried the carbamate too. Yes, we are filtering the effluent. Since my last letter, we had successfully precipitated out zinc using Magnesium Oxide and a proprietary organometallic polymer 326-C. But now we are having problem removing Nickel. This is not caused by 326-c. We had the problem with Nickel to start with. One more chemical we tried in the last couple of days is Ferric Chloride at around pH 8.0. Please suggest any chemicals to remove Nickel and at what pH, they work best. Thanks again for your reply. -Prasad. prasad surapaneni
Dear Reader: please choose what you want to do.
Save
