letter 0013
- Hi, Dany. Thanks for visiting. References you might consider are: Chemical (Electroless) Nickel Plating by G.G. Gawrilov or Electroless Plating: Fundamentals & Applications by Mallory and Hajdu You may wish to contact suppliers of electroless nickel solutions, such as: --or manufacturers of brush plating systems, such as:
++ Electroless nickel is a coating designated to protect metallic part of any shape against corrosion-erosion in oil industry application, for example, in choke boxes, control valves, spools, pumps, pipes, and others where corrosion and erosion resistance are required to reduce operational cost and extend lifetime of components mentioned above. José Wong
Save
This Page (why?) - Home - ©1995-2009 finishing.com
