Letter 0004
Making Current Shunts Solderable
Hi,
Our company has had serious problems with solderability of small (0.5") alloy wires (10 AWG to 24 AWG) we use as current shunts for sensing overload and short circuit conditions in our switching power supplies. A temporary solution has been barrel plating a copper strike followed by .0003 -.0005 tin plate. This works until you get to the thin wire gauges. Can you suggest any other solution? The alloy is called Alloy 90. It does not solder well in a no-clean process.
Thank You,
P. Lopes
power systems
Do you need to use a no-clean flux for your process? This is one of the more difficult to use processes, and consequently will require a very solderable surface. But to the meat, is Alloy 90 a 90/10 Nickel/Iron alloy, as the name would imply? If so keeping this gem solderable could be a challenge. Probably some sort of plating is mandatory. But it is difficult to plate very small wires.
Would you consider immersion plating? If so, we have recently put together an immersion plating bath for Palladium that seems to work well on pure Nickel. If the alloy is what I suspect, this might work well for you. If the alloy is as I suspect, we would be happy to run some samples for you.
This finish is inherently not the easiest to solder to in the world, but we have had some no-cleans work well, and the good news is, that if it works well fresh, it will not change solderability characteristics over the next year.
Rudy Sedlak
Mountain View, California
-Is it 90 Sn / 10 Pb, or other?
Mike Lang
Coopersburg, Pennsylvania
Alloy 90 is a copper nickel alloy 88 Cu/12 Ni. The 90 comes from the resistivity of the material (90 ohm-cmil/ft).
Todd Dietsch
fuse mfgr. - Des Plaines, IL
Dear Reader: please choose what you want to do.
I want to answer or follow up this question
I want to post a question or inquiry of my own
This letter is within a monitored forum, very much "alive" here in 2008. If you spot any broken links or obsolete info, please advise!
