finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 001
Electroplating Skulls, Leaves, Flowers
Q. Can you suggest sources of info on electroplating or bronzing organic material such as animal skulls?
[name deleted for privacy by Editor]
A. Besides the electroplating societies (www.nasf.org) and the links you find from finishing.com, and the electroplating texts we recommend, I can tell you quickly what my experience has been for this kind of work.
1) I always used "other people's" electroplating facilities. That is, it was a hobby for me, so I used a plating tank during lunchtime or whatever. If you have an electroplating facility available, that's great. If you are thinking of setting up your own tanks, it's possible, but in today's world, it means wastewater, waste sludge, permits, etc.
2) I never plated big stuff, but for the nuts and berries and leaves I fooled with, I used a silver conductive paint. I think it was called Electrodag or something. I think you might be able to airbrush the paint onto the subject.
3) It requires a little technique for starting the plating strike with low current and many contact points so you don't burn off the silver paint.
4) The biggest problem, I think, that you need to overcome with organic material is sealing the thing so plating solutions are not absorbed during immersion. It ruins the job when you have tiny points of bleed-out which corrodes and destroys the look. You might try multiple dips or sprays of a wax, then paint the wax and plate. So watch out for hot solutions which will expand the trapped air. (I know a person who plated a banana and it blew up in his desk, so remove the brain before plating skulls.) Or how about making a mold of the skull, then a reverse of plaster, then plate that?
5) Ted Mooney is getting a copy of this letter. He told me that they electroplate orchids somewhere in the Far East. Those are the people you want to talk to!
6) Good Luck, and send me a photo of your work when it's done. I may want one for my house in Vail, if I ever get a house in Vail.
7) If I did or did not help, I would be glad to try again.
Animal skulls on eBay
A. I can tell you what is done to finish non-conductors in the (vinyl) record industry and in our business (electroforming coaxial cable devices).
In vinyl record production (I did this years ago) an acetate master is cleaned, sensitized, then sprayed with a two component silver compound which lays down a very thin coating of pure silver. This silver is the conductor on which nickel is then plated. When plating is done the acetate is peeled off, the silver is stripped, and you have a negative image from which to press additional records or from which to make "Mothers" from which to make additional pressing plates, ad infinitum. Each plating cycle introduces more micro defects which show up as hiss, etc. so there is a limit as to how far you can go.
In our current process, a shape is injection molded with special wax, then cleaned, sensitized, and sprayed with the same silver spray system as above. Then we copper plate to a thickness of 10-20 mils. The wax is evacuated and the remaining shape (a precision electrical cable/connector assembly) is trimmed to spec and undergoes final test/assembly.
Bill Vins
microwave & cable assemblies
Mesa (what a place-a), Arizona
How to Electroplate Non-Metallics for Extra Profits
S
I
D
E
B
A
R
There was a reference to plating orchids. I wondered if this was a put-on, this is mighty close to gilding the lily.
Ward W [last name deleted for privacy by Editor]
aeronautical & navigation- Louisville, Kentucky
Thanks, Ward. Gold plated orchids are a reality =>
... but thanks for the chuckle!
finishing.com
Brick, New Jersey
I read your postings at finishing.com and I found them very interesting, congratulations.
I want to ask you if you can help me on how to prepare organic stuff like flowers or insects making them ready for gold depositing or plating.
Thanks a lot in advance
Humberto M [last name deleted for privacy by Editor]
- Mexico
I am a GCSE student in Chichester, England. I have taken is art & design. I saw something on the net about electroforming over leaves, I would love to do this as part of my project and was wondering whether anyone could tell me how I would go about this? Any help would be very helpful.
P.S. I can probably get everything from school but a list would be helpful.
William G [last name deleted for privacy by Editor]
-Chichester, England
December 26, 2008
sounds very interesting. I hope you will succeed. Good luck!
Lisa Wong
- Qingdao, China
Learn more about plating organic materials from our FAQ. Good luck!
finishing.com
Brick, New Jersey
May 17, 2009 -- this entry appended to this thread by editor in lieu of spawning a duplicative thread
Q. Does anyone know how to metallize (different metals/colors i.e. bronze, pewter, silver, etc.) skulls or bone?
Jim Spencer
hobbyist - Greenwood, Indiana
August 6, 2011
A. Hi, Jim.
We appended your inquiry to a thread that at least partially answers it. Once the object is metallized you can electroplate it with nickel, bronze, copper, silver, or whatever plateable metal you wish as an alternative to gold plating. Good luck!
Those who are interested in this topic will probably find the following threads interesting: letters 566, 934, 15106 and 44688.
finishing.com
Brick, New Jersey
