Letter 9403
Neil Bell |
Use Pen Gold Tester . Testing makes green rhodium ink, turns white solid nickel/gold surface to pure gold, and platinum/gold forms a yellow-red ink.
Andy Reiss
- NY, New York
There is NO SUCH THING AS WHITE GOLD! It is ALL rhodium plated!
Tai Wade
- Los Angeles, California
++++ Sorry, Tai. But you are in error. Although most white gold these days is indeed rhodium plated to make it shinier and whiter, white gold is an alloy of gold and nickel or gold and palladium that is definitely quite whitish. As the rhodium wears thin on a white gold piece it is just barely noticeable; but as the rhodium wears off of a yellow gold piece it is very obvious because of the stark contrast. That is why it was never considered acceptable to rhodium plate yellow gold, although it seems that some jewelers are doing it today instead of stocking the pattern in both white and yellow.
++++ Hi Michael I have two methods for you to try Both use the specific gravity test to determine the gold content of your ring, one is a formula, the other is a chart. Method 1 Step: 1) Weigh your ring eg: 10.00 grams 2) Place a beaker half filled with water on a scale. The scale will have to be re-zeroed with the beaker & water on it. If it does not have this feature try turning the scale off then on with the beaker & water on it. See your local butcher if you cant get hold of a scale. 3) Attach a fine thread or hair to the ring and submerse it in the water. NB it must be fully submerged but suspended "not touching the sides or bottom". Take the reading off the scale eg: 0.56 grams 4) Divide the dry weight of the gold by the suspended one eg: 10.00 \ 0.56 = 17.8 5) Multiply the result by 5.096 eg: 17.8 x 5.096 = 90.7088 percent gold. Method 2: using the result from step 4 match it to the row titled weight. The value adjacent will be the percentage of gold present. eg 17.8 92% "close enough to the previous test!" Weight % 11.37 45 11.53 47.5 11.64 50 11.8 51 11.91 52 12.02 53 12.12 54 12.42 57 12.52 58 12.6 59 12.69 60 12.8 61 12.93 62 13.06 63 13.19 64 13.31 65 13.46 66 13.61 67 13.77 68 13.92 69 14.07 70 14.22 71 14.39 72 14.52 73 14.68 74 14.83 75 15.06 76 15.29 77 15.53 78 15.76 79 16 80 16.15 81 16.3 82 14.45 83 16.6 84 16.75 85 16.9 86 17.05 87 17.2 88 17.35 89 17.5 90 17.65 91 17.8 92 17.95 93 18.1 94 18.25 95 18.46 96 18.67 97 18.89 98 19.1 99 19.3 100 Regards Scott, Alexander
April 13, 2009 Does the specific gravity test only work on purely gold rings? For example, this test would be flawed if testing a ring with a diamond on it, correct? H.D. Jennifer
Save
This Page (why?) - Home - ©1995-2009 finishing.com
