HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 9094
STAINLESS STEEL COATING
WE WANTED ASSISTANCE IN TWO MATTERS.
1. WE DYEING MACHINE MANUFACTURER USING STAINLESS STEEL. WE WANTED TO IMPROVE COSMETIC LOOK,AS YOU AWARE THAT MACHINE M MANUFACRING PROCESS REQUIRES LOT OF WELDING, GRINDING WORK
2.WE WANTED TO KNOW MORE ABOUT HEAT RESISTANT COATING FOR STAINLESS STEEL
M.MARIMUTHUPENINSULA ENGINEERS - Coimbatore, India
Dear Mr. Marimuthu:
For cosmetic appearance I understand to eliminate stains, welding scale, etc. For that, you should pickle stainless after all process with a mixture of 30% nitric + 5% hydrofluoric. For heat resistant coating there will only be very expensive solutions because stianless is already very heat resistant, so anything that will surpass it is going to be sophisticated like say vapor deposited Titanium Nitride or sprayed ceramics.
