finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 9089
Electro Galvinized plating questions
Hello everyone,
Before anything please excuse my lack of knowledge in the plating field. A quick response to my following question will be most appreaciated. Could some one explain the pro and cons of using pre-plated material (i.e. EG) instead of post-plated if the enviroment at which this material would be exposed will be humid, hot, and possibly close to the sea.
Thank you!
Best Regards,
Luis Aguirre
- San Jose, California, USA
Preplate material is fine, until you cut holes in it! Any punching or cutting leaves areas without any plating and therefore no corrosion resistance.Preplate is used quite often in computer assemblies that operate in climate controlled conditions.Exposure to a moist, salty enviroment would require a good, even coverage of some highly resistant coating.You are fortunate to be in an area of California that offers an assortment of metal finishing shops that can assist you in your needs.
Good luck,
Bill Grayson
- Santa Cruz, California, USA
Pre-plated material is almost always less expensive, and that is the principal reason for pre-plating. Depending on the final shape of the part it is also possible that pre-plating will give more consistent thickness. The advantage of post plating is both decorative and functional. Pre-plated material has sheared edges which are not plated, and which, depending upon a lot of "ifs, ands, and buts" can obviously therefore rust prematurely.
finishing.com
Brick, New Jersey
